What is this noise?
Discussion in 'Gen 2 Prius Main Forum' started by Njapilot, Jun 1, 2017.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    You can grab anything u want your not going to move the lca. You have to remove the strut and the outer cv joint to check for looseness. And silicone is really not a lubricant. It has very few uses in a car. you need grease. I like and use PB BLASTER CSP SPRAY. It's a spray grease works really good. I use it all over the front end door locks door hinges hood lock mechanism anything that moves. Lca bushings too.spray some in the drivers side door lock. Somedsy you'll go to use it and it will be rusted shut. CSP can be found only at Home Depot.
    At this point I would get the front end up real high and get under there and tighten every bolt u can see. Especially the stab link ends.Bring a lot of light.
    But if the front end has aftermarket crap installed it's not going to work very well.
    #21 edthefox5, Jun 4, 2017
  2. Njapilot
    Njapilot Junior Member
    29
    DFW
    So use toyota stab link bars? Do you guys think I need a new alignment if I replace the stab bars?
  3. Njapilot
    29
    DFW
    Thanks. Will try that.
  4. edthefox5
    10,096
    4,836
    Clearwater, Florida
    No not bars just the end connectors the stab links. Use Toyota for those. They make alot of noise when they come loose and the chinese crap will not stay tight. Go online I like Olathe Toyota bought alot from them there pretty nice and the guy who does the Internet sales there is really cool.
    No alignment neccesary on stab links. Its only when you change the relationship between the strut and the knuckle. And possibly replacing the lca's but they are alot of work. There bolted to a sub chassis assy that has to be removed or the bolt that holds the lca will not clear the engine.
    But lca's when worn out make one noise only thats a clunk when you go over potholes if really worn they clunk on even the smallest depression in the road. Very distinct clunk. I've heard that sound many times over the years.
  5. Njapilot
    29
    DFW
    THanks! Is that the same clunking noise is my video?
  6. Njapilot
    29
    DFW
    I was hoping it would be this easy.
  7. edthefox5
    10,096
    4,836
    Clearwater, Florida
    jeez...scotty kilmer.
    m.wynn likes this.
  8. R3PB
    R3PB Junior Member
    Santa Fe, NM
    Premium w/ Solar Cells
    Fixed it! I took my Prius in to be diagnosed. They attach sensors at likely points, drive it, then analyze the recorded results. They narrowed it down to the steering assembly, and found a Toyota service bulletin which pointed to a problem with loose lower steering spline (and also recommended replacing the tie rod ends). Total cost for repairs would be about $1700. Total cost for diagnosis was $110, which ended up fixing the rattle! For now, at least.
  9. Njapilot
    29
    DFW
    Thanks. Still haven't fixed my car yet. Been out of town for a couple of weeks. Any more details on the TSB?
  10. Ajourney101
    Ajourney101 Member
    127
    88
    Seattle
  11. edthefox5
    10,096
    4,836
    Clearwater, Florida
    Those are the stab links. There connected to the stab bar.
    valde3 likes this.
