What is this part under the engine? Something like water drips out of it.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Moses Bruh, Jun 2, 2019.
  1. Moses Bruh
    Moses Bruh Member
    97
    29
    I was rotating my tires and i notice some water on the ground and it seems like this spout has liquid or water dripping out of it? Can someone tell me what that is and is it supposed to have water coming out of it.
    49,700
    not sure what part you're looking at, a/c drain?
    Raytheeagle likes this.
  3. bobodaclown
    bobodaclown Member
    214
    71
    Looks like ac condasation drain, it's normal to drain, otherwise it dressings into the car soaking the passenger floor mat.
    SM-T700 ?
  4. Moses Bruh
    Moses Bruh Member
    97
    29
    i circled the part that has a drip, i never noticed water before but good to know if its just the drain for ac
  5. bisco
    49,700
    i always get a puddle under my front end when i park after the a/c has been on
  6. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    It’s the AC drain line (y).
    Skibob likes this.
  7. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    Your 2nd picture encompasses the brake line.
    As everyone has said, most likely the AC condensation drain line.
    Logic: don’t turn on the AC one day as you drive. If you don’t see any water dripping, you have you answer.
    If you see water and you did NOT use the AC, you have a problem.
  8. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Yep. I helped a friend fix the AC in his hilux once and after a couple of days he says his floor is wet. I clear the drain line of mud inside it and the wet floors were no more.
