What is this sensor?
Discussion in 'Gen 2 Prius Main Forum' started by Kenneth Steere, Jan 15, 2026.
  1. Kenneth Steere
    Kenneth Steere Junior Member
    26
    Richardson, Texas
    Yes I broke it trying to pry the valve cover off.
    New cover is on without any problems but I need to replace this sensor.
    It's that one right next to the timing chain with a ground wire connected to the top bolt. It has a 4 pin connector that broke.
    (See attached photo)
  2. Tombukt2
    Tombukt2 Senior Member
    13,883
    2,521
    Durham NC
    Timing oil control valve . It's long too like 3 inches inside the engine.
    Kenneth Steere likes this.
  3. Kenneth Steere
    26
    Richardson, Texas
    Thank you...$78 mistake for local pickup.
  4. Kenneth Steere
    26
    Richardson, Texas
    On attempting to remove it part of The housing broke off inside. I was able to get the core out. Am I going to have to take the valve cover back off.
  5. Tombukt2
    13,883
    2,521
    Durham NC
    Looks like it is so you missing part of the sensor the outter cover. Unless needle nose can grab it ,?
  6. Kenneth Steere
    26
    Richardson, Texas
    I have a reverse threaded not extractor thats got a hold of it but it won't pull out.
  7. Kenneth Steere
    26
    Richardson, Texas
    Got it out...all good. used nut extractor to twist it out.
    priumium likes this.
  8. priumium
    priumium Member
    335
    81
    Sweden
    2013 Prius Plug-in
