What is this thing?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by robertsm, Nov 15, 2023.
  1. robertsm
    robertsm Junior Member
    Central IL
    Replaced my HID headlights today, and after adjusting beam height I moved the car and found this small u-shaped rubber hose. Anyone know what it goes to? I think it’s from passenger side, possibly near washer fluid reservoir?
    edit: it’s a 2009 touring
    edit 2: there appears to be foam in it. Maybe to act as filter?
  2. Tombukt2
    Tombukt2 Senior Member
    13,830
    2,510
    Durham NC
    Yes that's a breather tube that goes on your headlight housing there's a little titty that you'll see and that goes to it is to let moisture and vapor pass through the system If you look in the parts break down you may see a picture of it. I don't have a headlight assembly off to flip over and take a picture of it.
    robertsm likes this.
  3. robertsm
    Central IL
    Ah! That make sense. I must have knocked it off when I pulled the headlight assembly off.
    Thank you!
  4. robertsm
    Central IL
    Couldn't find the specific part description/number, but found someone selling a headlight assembly, and their image shows the part in question. Adding this pic as reference in case anyone else has this same problem.
  5. Tombukt2
    13,830
    2,510
    Durham NC
    Thanks for that I have a real problem posting pictures and voila now everyone knows where it is these are common on tail light and headlight assemblies in many imports and I guess nowadays not imports.
