What is this winshield washer part?
Discussion in 'Gen 3 Prius Main Forum' started by GFO, Sep 24, 2018.
  1. GFO
    GFO Member
    75
    49
    Larkspur
    Hello all,
    Hoping someone can give me the name and/or part number of this part. It’s the small [black] three-way valve that splits the front windshield washer fluid into two lines from the pump; one going to passenger-side windshield washer nozzle; the other to the driver's nozzle. I forgot to take a picture of it (will do so later if need be), but here’s a rudimentary drawing:
    Bit of back story: For the last 3-4 months the amount of windshield washer fluid that has been coming out of the passenger-side nozzle has been steadily decreasing. I tried cleaning the nozzle out with a very thin needle; that did nothing. About a month ago it finally completely stopped/clogged, so I only had fluid coming out the passenger side, all-in-all, a minor inconvenience as a single nozzle covers a lot of the windshield as it. About two weeks ago the front windshield washer pump stopped working, so it was time to act. I ordered a replacement pump from Amazon ($16.00 USD) and this past weekend I replaced it, about 40mins of work. I also decided to track down the cause of the passenger-side clog and get everything working back to spec, so I removed the engine hood inner covering (well, just the two plastic rivets on the passenger side) exposing the windshield wiper fluid lines and tracked the clog to the strange-looking T-fitting. Blowing air threw it via my mouth/lungs, I noticed that air would pass through the out-port to the driver’s side, but nothing to the passenger’s side; also noticed that is has an anti-drain feature, where fluid (air in my testing) can only go one way. I ended up replacing the fitting with a small standard plastic T-fitting from the local car part’s shop and everything works fine; albeit I get a bit more spray pressure, but it also takes an extra three or so seconds for the fluid to come out, I’m guessing this is due to my T-fitting not having the anti-drain feature. I would like to restore it all back to factory spes.
  2. ASRDogman
    ASRDogman Senior Member
    7,208
    3,771
    The original fitting probably has a check valve in it, and it clogged.
    You might have to remove the washer take and clean it out. It can get a film in it depending on the
    type of washer fluid you use. That's probably why your washer motor stopped working.
    What I did on Town & Country was remove the motors and use a hose at the top to flush it out.
    A lot of nasty stuff came out! I also sprayed out the pumps.
    I've seen check valves at different auto parts stores, just put it in line before the splitter.
  3. GFO
    GFO Member
    75
    49
    Larkspur
    Thanks guys, found the part cheap on eBay
