What is this?
Discussion in 'Prius c Main Forum' started by SuperABM, Dec 21, 2012.
  1. SuperABM
    SuperABM Junior Member
    71
    Orange County, CA
    I
    It looks like some kind of light sensor maybe? Right under the windshield on the dash. If auto headlights aren't an option what else would it be for?
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I'm not familiar off hand with the Prius c and how it is equipped loaded or overseas but if higher end models have a light sensor they still put it there with no 'guts' in it on lower equipped models. That's how it was with the regular Prius.
  3. Mik1
    Mik1 Member
    333
    Houston, TX
    I believe this is the solar radiation sensor for AC. None of the C equipped with auto lights so it is not a light sensor in my opinion.
  4. priusc123
    priusc123 Junior Member
    30
    Bay Area
    Can someone check if this "sensor" is on both side of the dash (ie. 2 sensors)? I had my windshield replaced recently and only see it on the left side. Don't want to call the mechanic if I don't have to. TIA.
    SuperABM likes this.
  5. RRxing
    RRxing Senior Member
    2,559
    1,833
    NEPA
    Ditto. It is part of the A/C system.
  6. KaliforniaKid
    KaliforniaKid 2013 Prius v Five 2012 Priuc c Four
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    Yep, it detects the amount of solar energy coming in through the windshield and adjusts the A/C to compensate.
  7. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    Thanks. I too had wondered about it. Now I know.
    Dan
  8. SuperABM
    71
    Orange County, CA
    I
    Yeah it's only on the left side in my car. I was just about to ask how many everyone else had. It almost looks like the right side should have one.
    priusc123 and CMJAnew like this.
  9. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
  10. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Mine is on the right side (RHD). My previous Gen1 is also on the right side. According to the Gen1, Gen2 and Gen3 Repair Manual, the Solar Sensor is only on the Driver side.
    From the Gen2 and Gen3 Repair Manual, this Solar Sensor is part of the Neural Network Control:
    I'm using SGII to read this Solar Sensor:
    Column 1
    0 [TH]XGAUGE[/TH][TH]TXD[/TH][TH]RXF[/TH][TH]RXD[/TH][TH]MTH[/TH][TH]NAM[/TH][TH]Notes[/TH]
    1 [TR][TD]Solar Sensor (D side)[/TD][TD]07C42124[/TD][TD]02CC04610524[/TD][TD]2808[/TD][TD]000100010000[/TD][TD1]SSD[/TD1][TD][/TD][/TR]
    If I cover up the sensor with a cloth, the value goes to zero. If I use a torchlight to shine at the sensor, the value increases as brightness increases.
    Vincent
  11. KaliforniaKid
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    In Singapore, so is your steering wheel and instrument cluster, correct?
  12. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    Yes, Singapore is right-hand drive (RHD), ie. people drive on the left side of the road.
