What is this ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 46mike, Jun 11, 2013.
  1. 46mike
    46mike Junior Member
    Rochester NY
    Duh...what is the "SKS" located under the steering wheel? thanks
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The SKS is for Smart Key System. On the Gen II models (prior to 2010) there was a button to turn off the SKS system if you were going to leave the car parked for a while in order to reduce 12V battery drain.
    The Gen III models do not have this button. The Owner's Manual says that after about 5 days the SKS will turn off automatically.
  3. 46mike
    Rochester NY
    Thanks much. I'm new to the site, but this is my second Prius. Do appreciate your reply as I've noted a lot of (ehemmm perhaps younger...) people don't write anything on their posts. Sign of the times I guess. Thanks again.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    That's to enable or disable the touch sensitive door handles. If you disable it, you can still use the key fob to lock/unlock.
  5. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved to the appropriate forum, not a website question
