What is this?
Discussion in 'Gen 4 Prius Main Forum' started by alexgrigori, Mar 13, 2017.
  1. alexgrigori
    alexgrigori Active Member
    163
    109
    Technology
    There is a brown rectangular device/sensor located below console next to the wireless charger with 2 wires connector. Any idea what it might be?
  2. DallasGuy
    DallasGuy Junior Member
    25
    Palm Springs
    No, but may I ask where you purchased your wood dash overlay?
    jtg61 likes this.
  3. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    No idea - I didn't think the wireless charger would be that big...
  4. alexgrigori
    163
    109
    Technology
    close view:
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Sensor for the artificial horizon? :D
    Montgomery, tucatz and RCO like this.
  6. alexgrigori
    163
    109
    Technology
    May be this is 'fob' sensor?
    robsnyder20 and RCO like this.
  7. pakitt
    2,173
    1,313
    Colorado
    Considering the location close to the phone charger, the BT antenna to connect to it I'd say.
    Also I looked up Qi Charging, and it is that big, because the coil is positioned dynamically closest possible to the receiving side of the phone, allowing you to simply put the phone where you want, essentially, on the black patch, and always get charging working.
    PS: the FOB antenna is in the "Start Engine" button on the dashboard, because that's where you need to place the key, in case there are communication issues between key and the receivers on the doors (e.g. battery in the FOB dead).
  8. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    Tracking device. Reports your coffee consumption habits to the nearest Starbucks.
  9. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Leave it unplugged and you'll work out what no longer works. That's if it doesn't lock you out of the car first!!!
  10. Elektroingenieur
    2,515
    3,288
    Three Touring
    The mystery part is the No. 1 Indoor Electrical Key Antenna Assembly, part number 899A0-60010 (list price $54.99 or ¥2,200), a component of the smart key system.
    The smart key system has two modes for starting: the one supported by this part, in which the car transmits an LF AM (134.2 kHz) signal and receives a VHF FSK (314.35 MHz/312.10 MHz) signal from the key in reply, and a second mode, in which the power switch on the dashboard reads a passive RFID tag in the key; the latter mode is used with a key that has a dead battery or is in power saving mode.
    Interestingly, because the smart key antenna is so close to the wireless charger, in both physical and radio frequency terms, the certification ECU (smart key ECU) can send a DIS (disable) signal to the wireless charger under certain conditions, to prevent interference between the two systems. I imagine that was a fun problem for the electromagnetic compatibility engineers to solve.
    luiset83, goldfinger, wrprice and 7 others like this.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Good post Elektro. We can conclude their engineers got it about right as the system seems to work OK.
    alanclarkeau likes this.
  12. alexgrigori
    163
    109
    Technology
    Thanks for all comments.
    Please note that for a few days this antenna was unplugged and removed from the car.
    Over this time the car was fully controllable and I did not notice any issues with access and/or driving.
    RCO likes this.
  13. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    IRS mileage verifier.
    Priifan and RCO like this.
  14. Montgomery
    2,254
    2,242
    Orange County, CA
    Anybody else notice the hardrive in the photo? hopefully its solid state, otherwise, meltdown is pending.
  15. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    It's not a hard drive - if you look closely at the label it says "Wireless charger".
    kevin
  16. alanclarkeau
    7,045
    7,593
    jtg61, RCO and Prodigyplace like this.
  17. Prodigyplace
    12,712
    11,848
    Central Virginia
    You expect us to read the labels in the picture??:D
    Thanks for pointing that out.
    Priifan and alanclarkeau like this.
  18. alanclarkeau
    7,045
    7,593
    When I first saw it I thought "CD/DVD player" - trying to get a perspective of where it was - but then worked out it was nowhere near it. Rotated and zoomed in - AHA!!
    #18 alanclarkeau, Mar 15, 2017
    Priifan and Prodigyplace like this.
  19. Chippingawayatlife
    Chippingawayatlife Active Member
    159
    116
    San jose
    I kind of wish your post never existed because it has some scary good information about the smart key. You know. Hackers and car thieves. o_O
  20. alanclarkeau
    7,045
    7,593
    Just live - they'll get in if they want no matter whether you worry or not. Here, PRIUS doesn't rate a mention on the most-stolen vehicle list.
