What is wrong with my 2007 Toyota Prius?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nathane37, Apr 8, 2021.
  1. nathane37
    nathane37 New Member
    Salina, KS
    Four Touring
    Long story short, my 2007 Toyota Prius has unfortunately stopped working. For reference, the battery was replaced around 120,000 from original owner, and it is currently sitting around 205,000. I did the battery level diagnosis, and it was sitting at 11.6V. Previous to this, I had the check engine light on for a little while, only having the error P0420, which has to do with the catalytic converter/O2 sensor. I was told that it is not that big of a deal, and it only slightly messes with gas mileage. I had ordered an 90 degree extender for the O2 sensor to be put on as soon as I got back, as that was everyone's suggestion to do for this error code.
    Drove it to the gym with no problem. When I was leaving, I suddenly got the infamous *red triangle of death*, where the Prius started to show a decrease in performance, went down on speed, and eventually gave out on me in a parking lot. Additionally, the VCS, parking warning light, and check engine light came on. I talked to a Toyota mechanic on the phone, and he suggested I try to put some gas in it, as I was on my last bar and it was possible that the fuel gauge sensor had been glitchy, thus I had run out of gas. However, after putting the additional gas inside of it, instead of fixing the problem, it actually CHANGED the problem. The *red triangle of death* was no longer visible, yet the VCS, parking light, check engine light, with the added indicator lights of ABS and the slip indicator (which indicates that the VCS is working, from what I have seen while researching) were shown as well. What is weird is when I held my foot on the break to imitate starting the engine/hybrid battery, it only acted as if it were turning on the electronics. When I would start it without foot on the break (to turn on electronics), and then put foot on break and press power button again, the car would shut off. To put this simply, it seems that only the accessory mode works, instead of ignition mode being able to work.
    I really don't know where to go from here. It might be the catalytic converter that needs replaced, it might be the battery. It also might be the brake system? Personally, my guess would be a new battery is needed, yet I'm not sure why these other indications would be presented, as accessory mode still works and what not. I would just like some educated guesses and possibly accurate diagnoses from anyone who may have experienced this before and/or are educated mechanics/car enthusiasts.
    Much thanks and sincerity in advance.
    52,927
    'i did the battery level diagnosis, and it was sitting at 11.6v'
    Raytheeagle and nathane37 like this.
  3. Mendel Leisk
    42,387
    And “diagnosis”, did this involve the car telling you the 12 volt’s voltage? How old is it?
    Regardless, better deal with the 12 volt battery first, seems very low: either recharge or replace.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Answer: It is a 14 year old car with over 200,000 miles.
    Seriously.
    You can't expect it to last forever.
  5. nathane37
    Salina, KS
    Four Touring
    Thank you SO much for that extremely helpful answer to my question. The Prius is 100% fixed, thanks to this!
    Raytheeagle, dolj and bisco like this.
  6. nathane37
    Salina, KS
    Four Touring
    As I ran the battery test, it came to 11.6V. I was thinking the battery is the problem as well, yet the key faub still works, and accessory mode/IGNITION ON mode still work without trouble.
  7. bisco
    52,927
    a low battery can operate some low powered things. making the car ready requires closing relays and getting proper voltage to computers.
  8. bisco
    52,927
    i thought you were serious for a minute :p
  9. dolj
    dolj Senior Member
    8,657
    4,408
    Wellington, New Zealand
    You need to get the diagnostic trouble codes read, one way or another. Don't expect good news.
    Just for giggles see what happens when you charge that 12V battery up overnight.
    TomLaNa likes this.
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    It would be helpful if you would think it through.
    That car likely will be a pain in the butt the entire time that you keep it.
    If you enjoy having something new go wrong every few weeks, or days, then you should love the experience.
    Most people don't.
