What is wrong with my timing P0016
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by johnnychimpo, Jan 30, 2021.
  1. ChapmanF
    19,020
    How did you end up with a tensioner half an inch shorter? From a different make or model of car?
  2. johnnychimpo
    johnnychimpo Active Member
    522
    112
    Monterey
    Craigslist
  3. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    OUCH!
    Well, hopefully, you learned something important from that.
    Plus, always match up the replacement part with original one.
    And there are some things that are just smart to buy new, and from a reliable sorce.
  4. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Even though the Gen 4 engine that I obtained for my project was at/near only it’s first oil change, I put a brand new tensioner on it before install. It’s just too critical of a part to skimp on.
  5. johnnychimpo
    522
    112
    Monterey
    I'm not a real mechanic I only play one on the internet. No seriously I think the damper springs are weak due to the head gasket rattle, so how hard is it to replace and is there a diagnostic procedure. Do you need to fully pull the engine or just partially separate it?
  6. johnnychimpo
    522
    112
    Monterey
    To wrap this up I confirmed the timing and replaced the tensioner. This resolved the P0016 but I also added new spark plugs coils and injectors. These Items needed to be replaced at 180k anyway.
  7. Mendel Leisk
    42,345
    It’s purring now?
  8. johnnychimpo
    522
    112
    Monterey
    No it still missfires, taking it to a specialist on Monday... He suspects a leak in the intake somewhere. Will keep you posted.
  9. Figster10
    Figster10 Member
    207
    61
    Sacramento
  10. johnnychimpo
    522
    112
    Monterey
    they could not figure it out. I double checked piston travel and found number four to go 3 millimeters lower than the rest. I suspect bent rod or worn bearing.
