What is your DTE after fill-up?
Discussion in 'Prime Fuel Economy & EV Range' started by Salamander_King, Oct 8, 2019.
  1. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    As pointed out in your thread, I think the first tank mpg estimation is very difficult. And I still think the only way to semi-accurately estimate HV-only mpg on PP is to do HV monde only drives for a tank without any EV mode drives. When you do that and compare it with the DTE method I have shown in this thread, you will be surprised how close those two numbers are.
  2. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    That's actually not fully accurate either. SOC between the start and end points can vary upto 20% with a depleted battery, which is about 7 miles, and that would be an error of 1% or more, depending on the miles driven. Of course, the driven miles shown on the odometer can also be 2% off. You may want to look at the battery icon on the MFD with a magnifying glass to have the initial and final values match.
  3. Salamander_King
    11,024
    8,980
    New England
    That discrepancy is negligible when you do a full tank drive on HV mode only without charging the traction battery. The point is to get more accurate HV-only mpg you just can not use EV mode and has to be a longer period of drives like a full tank or ~500+ miles rather than a single trip of 10-20 miles.
  4. Gokhan
    6,715
    2,672
    Paramount CA
    As I said the error can be 1% or more, as the HV SOC can wildly vary.
    There is also the possibility Prius Prime doesn't get as good an HV fuel economy with a depleted battery when it runs like a regular Prius because there is less flexibility on the EV driving. Obviously if you restricted the EV-driving scenarios, you would reduce the HV fuel economy. I don't know if the computer relaxes the EV-driving scenarios with the SOC, say, above 5% as opposed to fully depleted.
  5. Salamander_King
    11,024
    8,980
    New England
    After the EV range depletes for the first time, subsequent HV mode drives are all accounted for the HV-only mpg, so it does not really matter how much fluctuation SoC may swing under the HV mode only drive. Presumably, the same fluctuation occurs in regular Prius. I have tested HV only drive mpg on my commuting route with EV range depleted vs fully charged or 50% charged traction battery on my 2017 PP. Under my experimental condition, there was no statistically significant difference in average HV only mpg in those three conditions. I can't remember which thread I posted that result, but if I find it, I will let you know.
  6. Gokhan
    6,715
    2,672
    Paramount CA
    It does matter. I estimate a 1% error in the HV fuel economy on a full tank unless you deliberately match the actual initial and final SOC on the graphical battery icon on the MFD. In the extreme case, you can drive several EV miles in the HV mode with a fully depleted battery ("--" reading) before the ICE kicks in, giving you a 999.9 (∞) mpg HV fuel economy.
  7. Salamander_King
    11,024
    8,980
    New England
    It only matters on the very first time when you deplete the SoC to "--" reading. That's why I said, deplete the EV range first, then fill the tank and then reset tripmeter to 0, and drive only on HV mode without charging the battery until the next fill-up. To be exact, after the EV range is depleted, the car should be driven on HV mode for a while like at least 10-20 miles before filling the tank. At that point, you are calculating mpg on a 100% HV mode only drive.
    In any case, a 1% difference is within the statistical deviation range, so as an estimate, it does not change the overall accuracy.
    #67 Salamander_King, Jan 3, 2021
  8. Gokhan
    6,715
    2,672
    Paramount CA
    Yes, however,
    "--" ≠ 0% SOC.
    "--" ≈ −10–+10% SOC.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    So, (assuming those percentages are accurate) to use round numbers, 10% either way on SOC would be roughly three miles either way. Spreading that out over a full tank of, say, 550 miles is about half a percent.
    The surest way (least unsure) to know HV mpg is to start with a full tank and always put it in HV when driving and do that for a half tank or more and then fill it again. Anything else makes too many assumptions and even this way assumes the two fill ups ended with the same amount of fuel in the tank. The more miles on the tank, the more you dilute that potential error in fill volume. Still, this is plenty accurate as long as there's not an Olympic gold medal at stake.
    #69 jerrymildred, Jan 4, 2021
    fuzzy1, Hicksite and Salamander_King like this.
  10. Triparadox
    Triparadox Active Member
    201
    108
    I was driving with low pressure (about 33 psi for most tires with one being 29) for hundreds of miles. Filled them to 38.5 and went to gas station. Apparently I was still running 50 mpg.
  11. jerrymildred
    11,517
    14,171
    Tampa, FL
    I finally bought gas again. Sheesh! It's gone up over 25% since August!
    Latest DTE is 564 which is another new record since I started tracking it in October, 2019.
    I actually went, 3,553 miles on that tank and it took 8.71 gallons to fill it. I suppose I could have gone a lot longer, but just felt like it was time to freshen it up a bit. Also, I've got a 60-mile drive coming up next week and don't like doing that when the gauge is down to 1/8.
    Cost per mile including electricity was a bit higher than last time due to much higher gas price even though I went farther on one gallon less gas. Total cost of gas & electricity was $69.09 which is just under 2 cents/mile. Last tank was just under 1.7 cents/mile.
  12. Gokhan
    6,715
    2,672
    Paramount CA
    My third fill (second after dealer's fill) was 615 miles. I expect the fourth fill to be even higher. I guess I am a hypermiler.
    jerrymildred likes this.
  13. jerrymildred
    11,517
    14,171
    Tampa, FL
    I tend that way a bit. But the traffic engineers here went to a special school where they learned to set speed limits and traffic lights so that most people spend most of their time either braking or accelerating. It's infuriating.
    fuzzy1 and Gokhan like this.
  14. DavidA
    2,349
    1,825
    Chicago western burbs
    I'm down to 1/3 tank now after filling up in 2019. Thats progress I guess. Was $2.059 way back then. Sadly, 2020 saw only 1,850 miles driven, because... COVID. I've got 2,150 miles on that tank so far, obviously almost all of it electric. And my 12v battery is almost dead.
  15. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    663581DE-0880-4B44-A695-653F385CBF69.jpeg I visited a gas station for the first time in about a month, which has been a lot nicer than weekly visits when the Tacoma was my daily commuter.
    The gas gauge was somewhere around 1/16 tank remaining when the fuel light turned on. Since this was my first time playing the DTE game I didn’t want to chance it and filled up a few miles after the light turned on.
    The Prime took 9.13 gallons and reported 508 miles DTE. So 55.6 mpg for 95% freeway speed driving (I run it in EV mode getting to and from the freeway, on downhill slopes in the freeway, and in stop and go freeway traffic). Next time I’ll push the limit a bit further now that I know there was plenty of fuel still in the tank.
    jerrymildred and Salamander_King like this.
  16. pierced
    pierced Junior Member
    50
    Norway
    2012 Prius+ MPV
    Business Edition
    Sorry.. Wrong window..
  17. DavidA
    2,349
    1,825
    I finally filled it the other day. 15 months on a tank. Even then, it only took 7 gallons. Reported 560 miles post fill up. I immediately used a few gallons for the COVID vaccination second dose trip 3 counties away.
  18. Gokhan
    6,715
    2,672
    Paramount CA
    DTE for my fourth fill is 647 miles. Is this considered any good? My third fill was 615 miles. 700 miles still seems far away.
  19. jerrymildred
    11,517
    14,171
    Tampa, FL
    No, not good. GREAT!!!!
  20. Salamander_King
    11,024
    8,980
    New England
    Congratulations! Yap, that is a new record. Beating the old record of 644 miles set by @droplet. What is your DTE after fill-up? | Page 2 | PriusChat
    Anything above 600 miles is considered to be excellent in my view. I have never achieved above 600 miles.
    #80 Salamander_King, Mar 24, 2021
