What is your miles/kWh (total average electricity consumption) on the "Drive Monitor 2"
Discussion in 'Prime Fuel Economy & EV Range' started by Salamander_King, Jun 4, 2019.
  1. Salamander_King
    Salamander_King Senior Member
    11,017
    8,950
    New England
    That seems to be the norm. That is another reason I can't convince myself to switch to a BEV. Even if they are available, the economics of charging on the road is simply prohibitive. Although I have not yet to see any charge station, from what I read here the cost of a charge station for a fee seems to be much higher than my own electricity at home. And for me, at the current price of gas, even charging at home is more expensive than gas.:(
    jerrymildred likes this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    That's sad. And possibly criminal. :( Our gas isn't the cheapest, but it's not bad. Just went up to about $2.45 a day or two ago. But electricity is only about 11.5 cents/kWh. Long trips using gas cost me about 4.5-5 cents/mile. Typical driving here costs me about 2-2.5 cents/mile.
  3. Salamander_King
    11,017
    8,950
    New England
    The gas cost is actually similar hear. It has been staying at $2.46 almost all summer. It may go down a bit now the summer is over. Our electricity is currently 19 cents/kWh. At this price, the gas and electric both are at 4.5 cents/mile, but I have been using grocery points to get the gas at discount anywhere from $1.50-$2.00/gal. Which makes gas cheaper than electricity.
    benagi and jerrymildred like this.
  4. Tideland Prius
    16,556
    Same here regarding paying for charge. I use free chargers where available because the fee is per hour based on 6.6kW. The Prime can only accept 3.3kW so even if there’s no one else at the station, I can make full use of the max charging rate so it’s effectively 2x the cost for a Prime owner since we charge at half the rate. At 55mpg, gas is cheaper. (And I can get over 60mpg in the summer).
    Salamander_King likes this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Move out to where gas is averaging just a touch under $4 a gallon and the electric charging makes sense ;).
    And with solar, it’s paying for itself in multiple ways(y).
  6. Tideland Prius
    16,556
    or where gas is $4.69/gal and elec. is 9.5¢/kWh.
    Raytheeagle and Salamander_King like this.
  7. Salamander_King
    11,017
    8,950
    New England
    Finally got my lifetime DM2 up to 5.0 miles/kWh. That's a 10% increase since June this summer. It was 4.5 miles/kWh. See my comment #1. I put ~6800 miles on my car and during that time, I have tried to increase daily "miles/kWh" as much as possible sometimes with the expense of using more gas. Even with using gas (HV) to increase EV efficiency, the overall mpg for the lifetime also increased to 85.1mpg from 84.0mpg, so it must not be wasteful overall.
    The challenge is how to keep this number during winter months.
    #147 Salamander_King, Oct 20, 2019
  8. El Dobro
    El Dobro A Member
    7,088
    3,270
    Does the car count electricity use when preconditioning?
  9. Salamander_King
    11,017
    8,950
    New England
    Good question, but I don't know the answer. I never use preconditioning in my car. My guess is, it does not count in the miles/kWh calculation since the car is not on the "Ready" state, but I might be wrong. Can someone who uses preconditioning regularly confirm or deny?
  10. jerrymildred
    11,517
    14,152
    Tampa, FL
    I do use preconditioning, but it would be a bit of a project to try to determine how the car accounts for it. You'd need some kind of controlled test.
    Edit to add: I do think, though, that it is most likely not counted for the same reason you gave.
    Salamander_King and Raytheeagle like this.
  11. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    I do preconditioning as well, and when I return to the Prime, it shows 100% and the miles / kWh are the same as when I left;).
    It’s like when you switch from EV to HV, the miles / kWh doesn’t change(y).
    jerrymildred and Salamander_King like this.
  12. Salamander_King
    11,017
    8,950
    New England
    Now thinking about this again, I think the precondition while plugged when wall charge is available, is likely to be not counted for EV efficiency. But how about the precondition when not plugged? Essentially, you are depleting the battery charge without doing any drive. If you use 1kWh of battery doing preconditioning, that's 0 miles/kWh.
  13. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Just like using HV mode;).
    I know I have depleted the battery while in that mode and the miles / kWh metric didn’t change:).
    It’s just a narrow way to look at things that only counts when it’s in either EV Auto or EV mode(y).
  14. Salamander_King
    11,017
    8,950
    New England
    Thanks for the info. Knowing that the "mile/kWh" value is strictly for EV mode (including EV portion of EV Auto) makes it easy to understand what those numbers mean. It is similar to the use of heat and AC during HV mode not being calculated in the A/C load.
    jerrymildred and Raytheeagle like this.
  15. yiujai86
    yiujai86 Member
    35
    31
    Miami
    2020 Prius Prime
    Yes it was all EV and I charge at work with a 115v charger. But i had to charge with the windows down to avoid using the AC while charging and also I was sweating balls all those days because I didnt you tje AC while driving. It was just a test I did to see what a hard core Hypermiling person would get.
  16. sutherlandws
    sutherlandws Junior Member
    Spring, TX
    Just lost my 2018 in an accident (I was rear ended) so I cannot pull up the lifetime numbers (11500 miles). However, I look at my daily commute numbers frequently. 40 miles round trip on city streets. This summer my best was 9.0 miles per kWhr. Average was about 8.5. At my best I did the 40 miles and had 22% battery remaining. The cast estimates just under 50 mile range for full EV charge. In the Winter, it was closer to 5 miles per kWhr and I could not make the round trip on a single EV charge.
  17. benagi
    benagi Active Member
    525
    280
    Utah
    Wow, those are some amazing numbers. Sorry to hear about your accident. Hope everyone was OK.
  18. NSXT
    NSXT Active Member
    137
    119
    Toronto, Canada
    2018 Prius Prime
    I am surprised today that I have achieved 12.7 kWh/100km = 4.89 mi/kWh with this type of weather.
    Feeling good :p
    Tideland Prius likes this.
  19. MSantos
    MSantos EcoAccelerometry
    589
    259
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    Nice. (y)
    Just do not drive to/in Winnipeg at the moment... :censored:
    Cheers
  20. Vavaq
    Vavaq Junior Member
    Vancouver
    2018 Prius Prime
    Upgrade
    My average after 17000km is 13.65 kWh/100km, so if I combine this with 5.46 kWh battery usable capacity it gives a range of 40km, and I do +/- 40km electric every day.
