What Is Your WORST Prius Fuel Economy?
Discussion in 'Gen 2 Prius Fuel Economy' started by jyl, Aug 31, 2009.
  1. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    On my 2 mile commute with soft tires and a lead foot I can do 37 but on a trip mid 40-low 50s (cause I do the tires before a trip and have less lead foot stuff.
  2. sfvb
    sfvb New Member
    17
    Northern IL
    43.74 MPG on day the after Christmas 2009, on a trip to Door County, WI. It was windy and snowy and averaged 19°F.
  3. ljbad4life
    ljbad4life New Member
    365
    24
    My worst MPG was 34.45 mpg (at the end of an entire tank) driving from nyc to boston in what was a remnant of a hurricane. Down pours, driving winds in excess of 45 mph 2 years ago. the part that killed my mpg was on I-95 from exit 70 to and through RI exit 8 the hills are steep and very little down hill.
  4. Dolce_Vita
    Dolce_Vita Member
    228
    25
    Sydney, Australia
    The very worst i have seen on my Prius is 45.2 MPG :(
  5. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    40.31 for an entire tank. Winter and nearly all trips < 5 miles.
  6. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    I don't see any follow up resposes. Did this mpg continue? :confused:
    Something seems really wrong and I'm sure many of us would love to know more. :eek:
  7. icohen2
    icohen2 New Member
    South Florida
    Hi. I have a Gen III with just a bit over 3000 miles on it. My gas mileage has been dropping steadily since I bought the car. When I first got it I was getting about 45 mpg in combined driving. Since then each successive tankful has shown less mpg. I just filled the tank and the gauge is showing about 33.5.
    I also noticed that the battery rarely goes above 2-3 bars (unless I'm driving on the highway). I suspect the car is running on the gas engine most of the time causing the low mpg.
    Has anyone experienced a similar problem? Is there something I'm doing wrong in the way I drive? Help! I'm getting ready to take it back to the dealer and see if they can find a problem.
    Thanks.
  8. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    Do you have a lot of short trips, many traffic lights or stop signs, and/or hills?
  9. rokibler
    rokibler Member
    88
    31
    Cabin John, Md.
    51.7 mpg per the MFD. It was in the winter of '08/'09 in mountains of West Virginia. Because of the bladder, I only track two types of mpg: the per tank MFD value and the cumulative value from a spreadsheet.
      File size:
      61.9 KB
      605
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I can see 37mpg if I run my heavy 17" performance wheel/tire combo and drive at speeds above 75-80mph. Generally I have to drive fairly aggressively to hit this number. Otherwise 39-40mpg is pretty normal for this setup.
  11. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    I've gotten 32.8 mpg I think it was. It was the middle of winter, I have a 3-mile commute, and the thermos (engine coolant storage tank) wasn't working right.
    It wouldn't pump the coolant when the ambient temperature was below freezing. This is actually a fairly common problem among Gen II vehicles. The dealer fixed it so it no longer makes weird noises in cold temperatures, but I'm still not sure it's working right in cold temperatures. But now I have an EBH and that helps the morning commute tremendously, so for that reason alone I won't get a tank in the low 30's again.
  12. mandrei83
    mandrei83 Member
    139
    32
    Stockholm, Sweden
    My LPG-powered Toyota Prius system starts to work when the engine reaches 15 degrees Celsius (after 2-3 seconds) and it consumes on this time some gasoline. Because of this, the gasoline tank manages to stay in my 45 liters tank about 4-5.000Km / 2.300-3.100 US/UK miles, while the consumption for LPG (including the one on gasoline) is:
    -in Bucharest/city is around 6L/100Km = 47MPG(UK) = 39MPG(US) = 3EUR/100Km!!!
    -outside city 5L/100Km = 56MPG(UK) = 47MPG(US) = 2.5EUR/100Km!!!
    My car was just converted into a LPG-hybrid, see the topic here.
  13. CBarr31
    CBarr31 Active Member
    436
    225
    Charlotte, NC
    I was looking at my various MPG recordings from tank to tank just today to finish my 200,000 mile write up and the worst tank I saw was 36.21 MPG. Which is pretty bad all things considered.
    Of course it was in winter and probably into a headwind but I don't remember specifics. Most likely some kind of 10% ethanol mix. Ethanol is just a bad bad bad idea for about 1,000 different reasons.
    Happy driving,
    Chris
  14. LightFlightDave
    LightFlightDave New Member
    30
    home
    Hi guys,
    I just got my 2007 touring Prius. So far according to the display I'm averaging about 35mpg. I've actually been driving pretty slow and really trying to get the mpg's up during my commute. My dad has the gen 1 Prius, he drives faster than I have been driving and he averages 50mpg. It's been hot the past few days but he tells me the AC should not be much of an effect.
    My father is a long time EV hobbyist, actually was president of EAA for about 10 years when they had presidents. He'd regularly win EV rally's for distance so he knows how to drive efficiently so I don't expect his numbers. Despite what this sounds like in the past when I drove behind him with my Subaru I was very impressed with the accelerations he would make and speeds he'd drive at. He still always maintains over 50mpg. I remember him griping about getting into the very high 40's once.
    I'm getting a strong sense something is wrong. I mean it could be me, but if I have to try harder than I already am I'm going to make other drivers really angry on top of it I would not be happy about my purchase. I've toned down my driving 200%
    I've tried accelerating slower and faster to get the miles up, but neither seems to work. I've read that about 1/3 throttle accelerations are optimal then just keeping constant once at speed. It's not working for me. I'd love to have someone with the same car reset the mpg then drive around say 5 miles, then do the same with theirs to see if it's me.
    All tires are about 41-42 psi.
    I am in the Bay Area Ca, The car is from Texas, I do not know what gas it was filled with, nor do I know what type of oil is inside. The Lexus dealer that sold it to me told me he changed the oil and filled up the tank.
    The only imperfection on the car was a small scrape by the rear right back wheel, I wonder if I should have the alignment checked. According to my father this might be a factor.
    I am very mechanical, if anyone knows anything I can check or has any ideas please let me know.
    I've only driven the car 3 days now but I do a bit of driving.
    Thanks!
  15. amm0bob
    amm0bob Permanently Junior...
    7,730
    2,547
    One weekend with my son, we decided to try to get the lowest mpg marker...
    Turned on all the lights and equipment...
    Jack rabbit starts, running it against kids in their mustangs/whatevers from the light, fast lane excessive speeds on the 5... mostly not legal driving I'll admit.
    Got it to 11.6 mpg...
    Had to fill up the tank in less than 100 miles in the county, it proved it was no sports car... and it didn't hurt the car at all to be driven like that...
    Still, the following month, I did everything I could to reduce the petrol use, and I got over 500 miles out of the same amount of gas...
    I was quite impressed.
  16. macmaster05
    macmaster05 Senor Member
    4,050
    730
    I had the same probelm when I bought my used Touring from Toyota. You need to hit the reset button and in a few days your displayed MPG should be 'normal' between 49-55. 35 mpg is not normal and a result of the prior owners driving it really poorly.
    Hit the RESET now!
  17. LightFlightDave
    30
    home
    I reset it already twice, I'm worried it's just my driving... I noted that resetting it on the highway while at 99.9mpg gets a high reading for a while, but it's back down to 35-36mpg now. The first time I reset it was before it was driven by me and it was at a stop which gives some really dissapointing numbers right away.
    I was driving quicker than I am and still averaging 28+mpg in my former 99 TD E300 Mercedes. I do expect much more than I'm getting from my Prius considering the comfort, weight, and size difference.
    Has anyone had MPG issues caused by alignment?
    Thanks again,
    -Dave
  18. macmaster05
    4,050
    730
    Hmmm that is odd. It worked for me... I would bring it in to Toyota, something is wrong.
    It's not your driving. The worst drivers still get 42 mpg.
  19. LightFlightDave
    30
    home
    I mentioned my concern to the service department at Redwood City Toyota they did not seem to care. To thier benefit, it was a very hot day for the service guy to be stuck in the outdoor booth there and I might be in the same mood if I was him. :target:
    I'll ask at Putnam in Burlingame, they seem nicer since they really took the time to talk to me about a knocking noise in the rear while driving and suggested possibilities. It could be because they get to work inside with AC:smow:
    I have a friend who I think has the same car, I'll try to get his opinion and see if he'll drive mine. I'd hate to bother Toyota if it's my fault, but I really think it should be doing much better on the MPG's.
  20. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi Dave. When I first got my Prius (S/H from a dealer) I was initially getting worse MPG than expected. Surprisingly the (at the pump) calcuated MPG was significantly better than the displayed MPG. Over time the displayed MPG got more accurate, I guess it adjusted to my driving style or something.
    BTW. What size and type of tires are you running?
