What jumps out at you ?
Discussion in 'Prime Fuel Economy & EV Range' started by Marine Ray, Sep 22, 2019.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    What jumps out at you? So much information in this gentleman's short 3 min video. My focus was on the engine temperature. This video confirms the engine did not turn on. Entire trip was in EV mode.
    benagi, noonm, TGrracie and 2 others like this.
  2. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    At the 1:40 mark of the video the % EV remaining = 49 at 1:45 mark the % EV remaining is 42
    26 miles EV at those speeds is impressive. Thanks John and Ray.
    noonm and Marine Ray like this.
    52,863
    nice! do they have one in the opposite direction?
    ice9 likes this.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Is this @john1701a 's video?
    What jumps out from the video is how "flat" the terrain looks to be. I would be interested to see the elevation profile of this rout.
    #4 Salamander_King, Sep 23, 2019
    Raytheeagle likes this.
  5. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Yup, that's mine. And you know, I live in farm country. It's extremely flat... with the exception of that downhill into the Mississippi river valley when approaching St. Paul.
    Salamander_King likes this.
  6. Salamander_King
    11,024
    8,980
    New England
    Yeah, I thought that scenery looked familiar. I spent some times in northwest corner of your state. The region was once a lake bed of prehistoric Lake Agassiz. That was the only place I have ever lived where I can see the flat horizon like that. You must get much better EV range because of the flat terrain.
    #6 Salamander_King, Sep 23, 2019
  7. Marine Ray
    1,139
    949
    Sparks, NV
    John - how do you put together these awesome videos? i.e. get MID and status in same screen, etc.?
  8. john1701a
    12,840
    5,312
    58
    Many years of experimenting, combined with the willingness to buy decent hardware...
  9. john1701a
    12,840
    5,312
    58
    The region here is actually rolling hills from glacial deposits, not truly flat like that.
  10. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Mind sharing your setup/specs?
    benagi likes this.
  11. john1701a
    12,840
    5,312
    58
    They keep changing. In fact, that latest video is already a disappointment compared to what I just filmed this morning. I enjoy the challenge of achieving higher and higher quality.
    My experiment today was to adjust the GoPro 7 settings for dashboard capture using ProTune options. That worked great. I was able to fix the washout, resulting in a much more crisp image while retaining color.
    Hope is to replace the window cam with a GoPro 8. Currently, it is a Sony ActionCam. The quality of the 4K capture for that should go up, a little better stabilization and brightness/contrast.
    As for the aftermarket data, that comes from the Hybrid Assistant app. I just capture the phone's screen, then edit it into the composite video afterward.
    #11 john1701a, Sep 26, 2019
    vvillovv likes this.
  12. vvillovv
    4,337
    1,519
    NY
    I changed up my routine a bit 2 days ago. The beginning of the trip was typical, but changed my normal rounte at the 8 mile mark (like Detroits 8 Mile Rd Eight Mile Road | Detroit Historical Society) After 9,5 miles I went another 5 miles, nothing special, just a few pics in groups
    start 1 - 4
    0 mile
    middle 5 - 7
    9.5 mile
    end 8 - 13
    15.3 mile
    And the GOM tipped up from 37 to 37.2
    #12 vvillovv, Oct 2, 2019
    benagi and Marine Ray like this.
  13. john1701a
    12,840
    5,312
    58
    Replacement of camera, computer, and software complete. The result was totally worth waiting for...
  14. Otto75
    Otto75 New Member
    Sopron / Hungary
    2020 Prius PHV
    John, the videos are great.
    One question: when the battery runs out and goes into hv mode ...
    if you go lightly after that, how much longer can you charge the battery?
    What the Hybrid Assistant shows you: 10-9-8 % ?
    Sorry for my English, I'm writing about Hungary.
    The prius plug-in is still one month away.
  15. john1701a
    12,840
    5,312
    58
    Assuming you are referring to the lowest draw, I believe that's 8%. But ever going that low would be rare. The engine does a good job of handling recharge.
  16. Otto75
    Otto75 New Member
    Sopron / Hungary
    2020 Prius PHV
    Thank you very much for your reply.
    Obviously, this is only interesting if you miss a few miles to get home and the charger.
    In the long run, over 40 miles, I also prefer the charging mode - ev mode pair.
    Charging mode - at high loads, for example on highways
    ev mode - in the city and at low load.
