What kind of hand calculated MPG numbers are you getting?
Discussion in 'Prime Fuel Economy & EV Range' started by Lemooron, Jan 24, 2017.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    DACD6902-2F2F-43D5-842B-C4CB0D6CFF08.jpeg DACD6902-2F2F-43D5-842B-C4CB0D6CFF08.jpeg 53D7CC73-64B9-41B7-934F-A2192B871351.jpeg C190C869-3E6F-42BD-A539-07D2BEC99A5C.jpeg t C190C869-3E6F-42BD-A539-07D2BEC99A5C.jpeg 53D7CC73-64B9-41B7-934F-A2192B871351.jpeg
    Last calculation was 110 mpg for 1060 miles on tank
    Best according to computer: 141 mpg. Sorry bout extra pics.
    51,948
    what are you getting at the pump, without plugging in?
    Andyprius1 likes this.
  3. Andyprius1
    2,327
    859
    Cool CA
    Why would anybody in his right mind buy any brand of Hybrid Plug in auto and then not plug in ? I don’t plan on removing the HV battery just to see what mpgs the ICE gets, it’s all integral, affixed, comes with package.
    Can you get this info on your 2012 ?
    51,948
    oh ya, just for yucks, 72 mpg.
  5. Andyprius1
    2,327
    859
    Cool CA
    And how did you go about figuring this out?
  6. bisco
    51,948
    i drove a tank without plugging in, back in the day, and calculated at the pump. fun experiment, but took a lot of self control. i hate driving hv.
  7. Andyprius1
    2,327
    859
    Cool CA
    Actually, I never plug in at the pump, fire hazard, old boy.
  8. bisco
    51,948
    stiff upper lip and all that?
  9. Andyprius1
    2,327
    859
    Cool CA
    However, it is impossible to drive even one trip w/o the automatic EV assist, helping the engine. It’s not possible to drive ICE only........and you did this for a whole tank? If you really did this, which I doubt, you could have hurt the engine.
  10. Andyprius1
    2,327
    859
    Cool CA
    exactement!
  11. Son of Gloin
    Son of Gloin Active Member
    421
    320
    Lafayette, IN
    I'm not quite sure I understand the "premise" of your comment here, but...
    ...the "best" any of us might do (short of removing the traction battery) to drive "ICE only" would be to make a lengthy road trip in which the battery is starting out so low-on-charge that the car "tells" us there's not enough "juice" to drive in EV mode. I've made ONE such trip so far... a trip that was probably at LEAST 90% HV one way, and probably at LEAST 95% HV returning home. On the roughly 345 mile trip (that's 345 miles each way), I hand-calculated 64.1 mpg going, and 59.2 mpg returning home.
    Around town / while running errands, I've gotten as high as 74.2 mpg (CAR's estimate... according to the dash display) on three different trips of 14 to 21 miles with two or three brief (10 to 15 minutes) stops. Even IF that displayed figure was 10% off / 10% high, that's still about 67 mpg....
  12. Andyprius1
    2,327
    859
    Cool CA
    I see what you are saying now. I have never tried that. However, I know when the car is in charge mode, it almost always attempts to charge, if I have run out of EV charge miles, then I go to charge mode. I believe, and I may be wrong but when not in charge mode the car still may charge a bit, but I’m not sure about that. The reason the car is called a hybrid is because of the great synchronization of the ICE and HV battery. I probably would never try your test as I am too parsimonious! The Ice assist the HV battery and the HV battery assist the ICE, n’est pas?
  13. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    Since plug-in completely throws off real mgp for PRIME, I drove my PRIME for a few weeks WITHOUT CHARGING after my last gas fill-up. Without using much of AC or heat, and no HWY driving, just mostly in town drive and daily commute on rural back road average speed of 28MPH, I averaged 66 MPG on display which came out to be ~63 MPG hand calculated. This is far better than my lifetime average 52 mpg for Gen3 Prius. Now I know what PRIME is capable of without any electricity, I am going back to nightly plug-in routine. My next fill-up should be in 2-3 month instead of 2-3 weeks. Only bad thing is that with this result, my break even point for gas vs. electric cost shift more in favor of gas.
    Mark57 and Andyprius1 like this.
  14. bisco
    51,948
    it uses the battery like a regular hybrid. all the energy comes from gasoline.
