What model# Yellow top battery for 2008 Prius-Where do I buy it?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Jan 3, 2019.
  1. Hamptgx
    Hamptgx Member
    66
    27
    Northern Illinois
    I'll have to get back to you on that, I'll be opening up the back again this weekend.
    Mendel Leisk and bisco like this.
  2. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    I had it wrong. The one for SKS is 174.19. 84 month. Toyota part number: 00544-21171-325
  3. Hamptgx
    Hamptgx Member
    66
    27
    Northern Illinois
    Whoops, found receipt, it's 00544-21181-320 thought it was wrong one but fits perfectly and no issues and I ain't dead from battery fumes yet. Can't blame my hair loss on battery, that's just old age. Was $199.00 OTD.
    51,896
    i just can't figure the non vented model, would like to know the safety engineering. it's not about normal operating conditions, but overcharging, or rear ending.
    if this is the correct battery, toyota should have a white paper. this info will be helpful to future buyers
  5. Skibob
    2,912
    1,502
    Northern California
    That’s bizarre I’m looking at the Tracy Toyota online parts website and its 00544-21171-325. I wonder if it has different numbers in different parts of the country?
    Your number comes up as discontinued.
  6. Hamptgx
    Hamptgx Member
    66
    27
    Northern Illinois
    I almost poked a hole (It had the socket spot for the hole but it was sealed there with no removable plug) in it but DUH caught myself trying hard to be stupid.
  7. bisco
    51,896
    i can't imagine the wrong battery fitting perfectly, it is a very odd size
  8. Skibob
    2,912
    1,502
    Northern California
    No the number says it’s for the Prius, but that number is discontinued
  9. Hamptgx
    Hamptgx Member
    66
    27
    Northern Illinois
    Suburban Toyota has it as 28800-21181 for my prius, GO figure, I'll probably die from my cigars quicker than I will from battery so I won't sweat it, always got a winder open anyhow.
  10. Skibob
    2,912
    1,502
    Northern California
    That’s an old number also. The way the battery’s are set up the air vents past the traction modules, thru the 12 v area and out of the car. It’s been pretty much proven the vent really isn’t needed.
  11. Hamptgx
    Hamptgx Member
    66
    27
    Northern Illinois
    It was EXACTLY/PRECISELY the same dimensions as factory battery I took out, trust me I measured it with my large calipers. Only thing was it had the socket molding for vent tube BUT no hole. I scratched my head for a few minits, told wifey where I got it and showed her receipt, told her if I die cause o this battery sue their butt's and she can get rich......she looked at me like I wuz nuts.....wives seem to do that kind of often.
  12. golfmk681
    golfmk681 Active Member
    264
    105
    los angeles, ca
    He’s the guy who I bought my used 2016 battery. Installed it himself. Legit guy.
    SFO likes this.
  13. joka
    joka New Member
    Currently Pep Boys does not carry the battery for 2008 Prius.
  14. Mendel Leisk
    41,402
  15. golfmk681
    264
    105
    los angeles, ca
  16. Mendel Leisk
    41,402
    And I haven't even had my coffee yet. :whistle:
  17. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    I think there are two Optima batteries you can use: large terminal posts and small post version for Prius.
    Some of us purchased the orig (large terminal post) Optima from eLearnAid.com, and we got the conversion kit for adapting the large terminal posts to Prius. So when our orig Optima died at about 7 years, I could not immediately get the small post version for Prius, so I opted for the large post version, since I can go either way on it. The vent tube did not seem perfect fit so it was not perfect.
  18. Skibob
    2,912
    1,502
    Northern California
    The nice lady that sold me her car did that also, but she did not keep the small terminals. Imagine my surprise when I bought a new battery for 174 from the dealer last week and found out I needed the original terminals.
  19. wjtracy
    11,367
    3,608
    Northern VA (NoVA)
    Yes it took me a while to find the orig hardware...I guess at the time we did it, we did not realize Optima was going to come out with the smaller terminals version for Prius
  20. jimolson
    jimolson Member
    155
    58
    Indianapolis, USA
    I just purchased an exact-fit Autocraft battery at Advance Auto Parts in Indianapolis for my 2009. It's an AGM battery of the DS46B-24R size. I had to order it because no Advance Auto Parts store had one. Price with online discounts was about $180.
    This battery went into the battery hole with no fit problems.
    Advice to other who replace their own battery: Use WD40 on the 11mm bolts that secure the battery strap and battery monitor box to the floor of the car. The treads of these screws are exposed to salty water under the car and were a bee-atch to get out. The torque required to spin them out approached what shears bolt heads.
    And FWIW, the brake malfunction lamp on the dashboard turned on after replacing the old battery. I'm gonna have to pay someone to turn that off.
