What oil to use for 2010 Prius with 150,000 miles?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GreenTea&SaltWater, Jul 25, 2021.
  1. GreenTea&SaltWater
    198
    58
    Los angeles
    And after how many miles does it require an oil change? Last I changed it was 5,000 miles ago. Also how do I find the oil filter I need? I’m shopping at Walmart btw.
    #1 GreenTea&SaltWater, Jul 25, 2021
  2. Mendel Leisk
    40,548
    Toyota dealership parts department is easiest; they're about $8 up here.
    C'mon... Toyota USA says 10K miles or 12 months, or 5K miles or 6 months, for "severe service". You can read up in the Warranty and Maintenance Booklet. If it's missing, you can download pdf from Toyota Tech Info, in the "Manuals" section.
    Grit likes this.
  3. Grit
    Grit Senior Member
    6,440
    4,184
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  4. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    Fram Ultra XG10358 is available at Walmart. Walmart also sells Mobil 1 0W-20 Extended Performance High Mileage (5 qt jug.)
    Check Mobiloil.com for any potential rebates available.
    moto g(7) power ?
    GreenTea&SaltWater likes this.
  5. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    How my 2013 II w/ 101,389 miles and driving in LosAngeles traffic, I go with 0W-20 High Mileage and its seems running smother and less more oil trap under throttle body. I change every 5K or every 6mos.
    GreenTea&SaltWater and ALS like this.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,351
    2,345
    Taylors, SC
    Unless you have seal leaks or weeping, you don't want to use high mileage oil. It swell the rubber seals.
  7. Grit
    Grit Senior Member
    6,440
    4,184
    Wilkes Land
    180,000 miles on mine, high mileage oil not in this engine yet.
  8. JC91006
    16,671
    8,516
    My 2010 with 137k miles is burning oil, I have not used the high mileage oil yet. Just top off whenever it gets low. It seems to be worse when I drive over 85mph on the freeway. I may try and engine flush before I do that. But I may have to go to high mileage oil just to reduce the oil consumption. Definitely changing oil every 5000 miles.....that should be for every car. That 10000 miles change is a way to sell you a new car faster.
  9. Georgina Rudkus
    3,351
    2,345
    Taylors, SC
    High mileage oil does nothing for degraded oil control rings. It only swells the engine seals.
    The low expansion pressure or tension oil control rings started to "degrade" from abrasive and carbon residue in the oil and clogging of the passages many miles ago. Nothing but replacing the rings will affect oil blow by except piston ring replacement.
    Exceptionally frequent oil changes is the only was to delay oil ring degradation.
    The Toyota recommended 10k miles is too long. 3-5k or every 6 months will assure longer oil control ring life and forestall blow by oil burning.
    #9 Georgina Rudkus, Jul 25, 2021
  10. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    UOA should be able to tell if 10k mi is too long....
    moto g(7) power ?
  11. Georgina Rudkus
    3,351
    2,345
    Taylors, SC
    It's not in the interest of the car manufacturers to promote the 3k miles oil change. The engine is warranted for 60k to 100k miles at the high end. The threshold standard for oil consumption is very high for a reason. It's to protect the manufacturer, not the customer.
    Oil consumption and oil control ring piston ring were and clogging will even become more prevalent in the future with the adoption of turbo charged engines and their higher operating pressures.
    That is one reason that I will never buy a car with a turbo charged engine.
    privilege and GreenTea&SaltWater like this.
  12. GreenTea&SaltWater
    198
    58
    Los angeles
    Hey, maybe I just like talking to you guys and that’s why I post all these questions xD
    plot twist I’m actually a mechanic at Toyota
    privilege and Mendel Leisk like this.
  13. JC91006
    16,671
    8,516
    Damn I'm not going to Toyota with my car anymore...twisted
  14. Mendel Leisk
    40,548
    OMG, I'm busted... :oops:
  15. ASRDogman
    ASRDogman Senior Member
    7,192
    3,765
    A Toyota Tech says get walfart oil filters???? mmmmmmm
    Okay Toyota Tech, WHERE in Techstream do I go to test the hybrid battery?
    I wanted to check the condition before I hooked up the Prolong Charger/Discharger and see
    how it will work balancing it out and reconditioning the cells....
  16. Grit
    Grit Senior Member
    6,440
    4,184
    Wilkes Land
    He is the feller that was camping in his car at a Walmart parking lot.
  17. ASRDogman
    7,192
    3,765
    Is that like the guy who is camped down by the river, in a van????
  18. Grit
    Grit Senior Member
    6,440
    4,184
    Wilkes Land
    he was the feller who posted a thread “where is the starter on the Prius” back while ago. And also everyone told him to buy a battery charger when he was stranded at Walmart. After he bought it, there was no power outlet in the parking lot to plug into charge the 12v bat.
  19. Grit
    Grit Senior Member
    6,440
    4,184
    Wilkes Land
    Not quite mi amigo.
    Limey Geoff likes this.
  20. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    I remember a time when I started driving and 1 yr/3000 mi was for our old Caddy, 1 yr/2500 mi for our old Mercedes Diesel, (severe service). Then I learned of synthetic oils, which back then emphasized the fact that they don't qualify for extended drain intervals.
    Now oil manufacturers are starting to follow Amsoil's 1 yr/25 k mi interval as Mobil 1 and Castrol are offering 1 yr/20 k mi oils. Just curious if people accept Amsoil's claim but not Mobil's nor Castrol's?
    (I noticed Valvoline is smart they're following customer non-acceptance and even though they offer an Extended Protection product it does not equate to extended drain intervals)...
    moto g(7) power ?
