What options do you have when you need to replace the battery?
Discussion in 'Gen 3 Prius Main Forum' started by Arsinek, Sep 12, 2015.
  1. Arsinek
    Arsinek Junior Member
    florida
    So I bought a 2011 at 85k. I figure the battery might need replacing soon. What options are out there for battery replacement?
  2. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  3. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    First off, is it the 12V aux battery you're referring to or the HV traction battery?
    If it's the 12V, not a big deal. It won't (or shouldn't) cost you more than $400 to have it replaced. Much less if you DIY, which you definitely should. Before you do, you need to test it. There are many ways to do this. Do a search and you'll fiind more than you need to help with this. I bought a AC DELCO 12V AGM battery at Pep Boys a few years ago. Works great. The original battery lasted for eight years and might have lasted longer but I didn't want to risk another winter with it so out it went.
    If it's the large battery behind the back seat you are asking about, it had better not need replacing soon. It's only five years old (or less). I know Florida is known to kill traction batteries because it's so freaking hot down there six months a year. Even if, it's still covered by the Toyota warranty for another 15K miles or 4 more years if you don't drive it very much in that time.
  4. Sergiospl
    3,938
    1,351
    28
    We're talking about the HV battery!
  5. jadziasman
    1,355
    488
    District 6
    And you know this how?
    Okay, the newb made two more or less identical posts - my bad.
    Peace.
    #5 jadziasman, Sep 12, 2015
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    In 100,000 miles you should seriously begin worrying for another 100,000 miles. <G>
    I do not think we have a statistical number of gen 3 batteries fail, if you had a Gen 1, we would know more.
    1) You could have the dealership put in a 'new' battery. This is the least labor for you and the most expensive. $3500 to $5000?
    2) You could have a remanufactured battery put in, either by a independent mechanic or yourself $1500 to $3000?
    Hybrid Restoration of Memphis | Hybrid Battery Specialists is close to me.
    3) Ebay has Prius batteries as more Prius crash than batteries fail.$700 to $1500?
    Toyota Prius 2011 in Other | eBay
  7. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    If your traction battery is good now, it's good;)
    Really, either you go new for 2500$ parts plus labor (when needed) or go used, used isn't new....
    But buying a used Prius, check out a dealer, have them check it, they don't have to fix it but they have to check it, if your not getting good mpg's presently.....
  8. Arsinek
    florida
    Im referring to the HV battery.
    Is it possible to replace an HV battery yourself?
  9. bisco
    52,912
    absolutely. in fact, it's fairly easy. you just need to follow directions carefully and use CAUTION around high voltage. your life depends on it. but there are plenty of threads here and utube that detail removal and installation.
    so you can buy new, salvage or rebuilt. all have their pros and cons.
  10. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    It helps have a friend, it may be too heavy to avoid damage to the upholstory.
    The first 7:30 should convince you that you can safely disconnect the high voltage cables to the inverter.
    #10 JimboPalmer, Sep 12, 2015
  11. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    What makes you think the battery would require replacement soon? I bought a 2010 at 230k and the battery is on par. Charges fully and discharges as expected.
    XT1060 ?
