What parameters define a bad strut?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrPete, Jun 24, 2025.
  1. MrPete
    MrPete Active Member
    507
    194
    Colorado, USA
    Doing my first DIY shocks/strut replace...
    ...and I am beginning to wonder if the typical "quick and easy" diagnostics are sufficient.
    Lots of people say either or both of:
    A) Does the car bounce if jostled or goes over a big bump?
    B) Is there evidence of a fluid leak from the strut?
    The ride on our 2011 has just felt off a bit. No obvious issues.
    I just pulled a rear strut and compared to a brand new one.
    The primary difference is in how long it takes to re-expand of I manually push in the piston while out of the car. Obviously not an in-car test
    New: around 10 sec
    Old: around two minutes
    Other than that, the old one displays no failure symptoms.
    Thoughts?
  2. Tombukt2
    Tombukt2 Senior Member
    13,724
    2,483
    Durham NC
    Look at sites like Monroe and kyb depending on tube designs you can read all about what happens to has as seals wear internally the stuff don't move thru the valve like it's sposed to gas and oil loss affect rebound all that good stuff.
  3. MrPete
    507
    194
    Colorado, USA
    #3 MrPete, Jun 24, 2025
  4. tweedle99
    tweedle99 Member
    125
    69
    Round Rock, TX
    My OE never developed any leak but had a lot of mileage and "felt off" like how you felt. The OE rear shocks never rebound when pushed in which meant that the springs were doing all the rebound.
    My replacement was Gabriel which later developed visible leak on one side and mfr warranty me the pair.
    I would recommend installing the rear sway bar. Makes the car less "squirrelly" on the freeway, especially on curves.
  5. Tombukt2
    13,724
    2,483
    Durham NC
    A larger sway ? Ones they're already is it not on the 3?
  6. tweedle99
    tweedle99 Member
    125
    69
    Round Rock, TX
    Mine definitely didn't come w/ a sway bar. I bought a TRD one a long time ago
  7. MrPete
    507
    194
    Colorado, USA
    There's a bar down there. They call it a "rear suspension brace sub-assembly" probably not a real sway bar...
  8. Leadfoot J. McCoalroller
    8,223
    7,725
    Pennsylvania
    2018 Prius c
    I believe in a shove test:
    Push one corner of the car firmly downwards. The springs should force the car back up- rebound. Then the car should move slightly downwards, settling back to equilibrium.
    There should not be any further motion. The strut is there keep the spring from "echoing." The ideal strut would arrest travel on the rebound stroke itself, but it's okay if there's a little settling after.
    Particularly bad struts can show up as controllability issues during braking, including longer stopping distances as a symptom.
    I don't know what to tell you about rebound times for gas-charged struts that aren't mounted on a car.
