What part is this?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Josho, Mar 23, 2021.
  1. Josho
    Josho Junior Member
    Albany, NY
    I have a 2008 Prius.
    The other day, I was inflating a tire when I heard a racket coming from the back end of the car. I knelt down and I saw that it was from a piece that seems to be above the muffler, encircling the top part, a piece with a pattern of little bumps. It's loose, I can see where one bolt is missing and another is disconnected.
    Sounds fine when I drive, though.
    What is this piece called? I want to be able to direct the mechanic's attention to it.
    Many thanks,
    Josh
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Heat insulation material/panel; used on just about every vehicle somewhere along the exhaust system. Any mechanic will know what it is.
    Raytheeagle likes this.
  3. Josho
    Josho Junior Member
    Albany, NY
    Thank you, Doug. I suspected it was just a heat shield, but it's great to have it confirmed.
    fotomoto likes this.
  4. NarklepticSnipr
    NarklepticSnipr New Member
    Indianapolis
  5. RRxing
    RRxing Senior Member
    2,559
    1,833
    NEPA
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,009
    NJ-USA
    As others have said, it's a heat shield- fairly common for the thin aluminum to corrode and fail right at the attaching screws.
