what percentage does running the a/c decrease mileage and why?
Discussion in 'Gen 2 Prius Main Forum' started by bagwell, May 12, 2006.
  1. removeum
    removeum Member
    407
    El Paso, TX
    B) The test was conducted with the A/C was set at max with full blower.
    When I drove out to California from Nebraska and back it was in August. I set the a/c at 74 degrees and on auto. Drove the speed limit 75 mph and only used a little over 68 gallons of gas on a 3150 mile trip. Which means I averaged 46.3 miles to the gallon and oh yea, the outside temperature was a mere 100 degrees.
    You just got to love this car. :D
  2. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    I couldn't even find where they said it was set on max blower and max cooling. But even with this the % loss will still vary with vehicle speed. There is no one number for everything. And a big % number under max output just means we have good high capacity air conditioners in our cars and says nothing about the true cost in real usage.
    I've tested my car quite a bit and I think the number they come up with sounds quite reasonable for some conditions. My worst case is driving home from work where the whole trip is not long enough for the car to cool down the dashboard. My mpg loss in this case could be 20% or worse but depends on traffic speed. If I can maintain 55 mph or better it isn't that bad but could be 10%.
    If I go on a trip at 65 mph for reasonable time so the car can cool the cost seems to be more like 3% in mpg.
    This with 100 deg F temperatures in sun.
    I have also tried testing with AC off and window up vs down, but that effect made no measurable difference I could detect.
    So on my commute home I try to leave AC off when I can stand it and open windows. On trips I use AC regularly, but set as warm as I can be comfortable. This helps keep my mpg up. When it is really hot and humid I just give up on good mpg and use AC, or if I have passengers.
    Generally I can count on at least 2 more mpg if I can leave AC turned off.
  3. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    here's some particulars of my daily commute:
    22 miles each way
    100% city driving with top speeds ranging from 40-53mph
    mornings I try never to use the a/c
    I use a car cover 90% of the time, so my car is not flaming hot when I get in it the afternoon.
    I'm in Houston, so its humid as hell most of the time with temps in the hi 80's to lo 90's right now in the afternoons.
    In the morning I can manage above 60mpg easily, on my way home however, with traffic pretty much the same, I can manage "only" in the lo 50's and figured it was the a/c usage knocking me down and sure enough, a couple of days without the a/c on my way home and I'm still in the hi 50's (57.6mpg) after 131 miles.
    by the way - Darell - I'm with you approx 99.9% of the time in your posts. I wish I could go buy an EV today. Every post I read from you makes me think, "why the hell aren't EV's more mainstream!?!??!?!"
    Its very frustrating to me.
  4. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    (Sorry for a littile OT here.)
    <div class='quotetop'>QUOTE(darelldd @ May 14 2006, 04:56 PM) [snapback]255107[/snapback]</div>
    My poing is that everything you mentioned above is included in the gasoline cost.
    You wrote "the energy for my AC is basically free at this point.", but I believe you'll see shoter driving distance when you use AC.
    Anyway, would you please let us know how much did your PV system cost, how much did you pay for the installation, how much do you pay for regular maintenance, how many Wh does the PV system generate, how many years does the PV system last?
    Ken@Japan
  5. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(ken1784 @ May 14 2006, 10:48 PM) [snapback]255552[/snapback]</div>
    Ah, that makes sense. I can also make a list of all the expensive stuff that is NOT included in the pump price of gasoline... but was actually trying to find a smooth way OUT of dragging this thread OT.
    Yes, my range will be shorter, of course. I think I covered that. I lose about 2-5% of my range with AC on. But NONE of that range comes from gasoline, and none of the power for my AC comes from gasoline.
    I paid about $11k for my 2.5kW system (including installation). There is ZERO maintenance (as with almost all PV installations). It is expected to last 30+ years - though I'll likely upgrade the inverter before then, and the panels do fade slowly over time. In 30 years, I'll have offset the equivalent of about half a million gasoline miles if I can manage to keep driving an EV that whole time. If gas stays at ~$3 (ha! Ya think?), that's about, oh..$55,000 worth of gasoline, and 400,000 pounds of C02 if I'm replacing an average US gasoline vehicle.
    And again - my point (now lost, and even pathetic when I first brought it up - but hey, it brings me back on topic) is that my AC usage does NOT change my gas mileage in the EV. For reference is this is the line I was was commenting on:
    My ONLY point was that NOT every car provides power for the AC via gasoline!
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,195
    Nixa, MO
    Back on topic a bit. I thought I'd plug a few numbers into Wayne Brown's latest THSII simulator program so folks could see some est. AC impact.
    Scenario: 65mph, 200lb load, no wind, 1300ft, elevation, OEM tires, normal pavement, 80% humidity, Baro-30.03.
    OAT 95degrees F-->
    AC on 67=52.7MPG
    AC on 75=53.9MPG
    AC on 85=55.5MPG
    AC off=57.3MPG
    OAT 85-->
    AC on 67=52.2MPG
    AC on 75=53.4MPG
    AC on 85=53.4MPG
    AC off=54.9MPG
  7. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    <div class='quotetop'>QUOTE(tomdeimos @ May 15 2006, 06:04 AM) [snapback]255378[/snapback]</div>
    The test sequences are described in ETA-HTP03.
    I think they opened all windows & doors so that those car with smaller cabin would not have an advantage over those with bigger cabin. The A/C load is still based on the test chamber volume and not cabin volume.
    Anyway, the test is just for fair comparison between vehicles and not your typical driving conditions. YMMV.
  8. faith2walk
    faith2walk Upgraded again
    154
    Alpena, MI
    <div class='quotetop'>QUOTE(KTPhil @ May 14 2006, 02:04 PM) [snapback]255248[/snapback]</div>
    Me too, I drive 300-600 miles a day. While I am cruising at freeway speeds (generally 65mph) I notice about 4mpg loss recorded on the computer. Not sure what they were using to get a 20% loss.
  9. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Thank you for the great information about your PV system.
    <div class='quotetop'>QUOTE(darelldd @ May 15 2006, 04:10 PM) [snapback]255565[/snapback]</div>
    I now understand you were saying your EV consumes some electricity, but no gasoline.
    Ken@Japan
  10. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(ken1784 @ May 15 2006, 02:49 AM) [snapback]255577[/snapback]</div>
  11. BaconGrease
    BaconGrease New Member
    I don't have a Prius yet because my 1998 VW Jetta is running well and averaging 52 mpg. However, by the time I need a new car the USA may well outlaw stinky polluting diesels, leaving me to consider a Prius as a replacement option. One of the ways that VW manages to squeeze over 50 miles from a gallon of fuel is that the motor doesn't use any fuel at all when the engine speed is above 1200 rpm, and the driver's foot is off the accelerator pedal. When the engine speed drops below 1200 rpm fuel is introduced to maintain an idle & prevent stalling. So coasting up to a traffic light in neutral uses more fuel than downshifting through the gears because downshifting is one of the two condtions where the moving vehicle uses no fuel. The other is going downhill (in gear). Gravity keeps the motor turning above 1200 rpm while the driver's foot is off the accelerator pedal, so the engine burns no fuel going down hill. Gravity also turns the AC compressor down hill. So when driving in the mountains, I switch the AC off going down hill and on going uphill and the car cools off for free. Unfortuately, this technique doesn't work on well flat terrain.
  12. djkarrels
    djkarrels beermandave
    Wauwatosa, WI
    Hi all, I've noticed the mileage in my prius going down as the weather gets warmer in Milwaukee.
    I use it (still need a name) for work, so I'm in and out of it all day long. I don't crank the ac, but I do have it on. Sounds like I'm better off lowering the windows, or at least spending a couple of bucks for a sun shade.
  13. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    16
    Racine, Wisconsin
    <div class='quotetop'>QUOTE(beermandave @ Jun 7 2006, 06:16 PM) [snapback]267545[/snapback]</div>
    I live 26 miles south of you. In January I was getting around 46mpg. Now, in June I am getting 53.9mpg. I use AC when it's hot outside. But you shouldn't be noticing a drop when the weather gets warmer. Just the opposite. Something doesn't add up.
  14. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    Well, I usually do not use A/C since my office is around 60 deg so my commute home I try to absorb all the heat to warm back up. However, when I have guests like today I use A/C. My MPG went from 67.3 to 66.2 just going 18 miles with the A/C on in 102 deg temp on flat roads (tank is at 318 miles so it does not shift much). hahaha I had to chide myself about getting angry with the drop in my possible all time high score on the buiilt-in Consumption computer game.
    I am not sure why either. Could it be the road heats up the tires, making them more full? In the morning my psi is around 41. When I go home in 102 heat they are around 45 psi. oh also they switch to summer gas (no ethonal).
