What Prius Prime needs.
Discussion in 'Prime Main Forum (2017-2022)' started by EV Happy, Mar 6, 2020.
  1. Trollbait
    12,800
    The gen2 Volt started at $33,520. The model has sold as well as the Prime in past years. Some of those years were the higher priced, shorter EV range gen1. A gen2 Prime with a 50 mile range, would need a smaller pack because of the Prius efficiency, and access to better batteries. It would cost more than the current one, but Toyota could probably keep the base price under $30k.
    Air cooling could be done right for larger packs, but it seems to have higher costs than liquid cooling. Cells that can withstand higher temperatures are needed. These cost more. Then the space required for proper air flow means the pack is physically bigger, so more space lost to the battery.
  2. smyles
    smyles Active Member
    332
    229
    US
    2020 Prius Prime
    You're kidding, right? It took close to $10k of incentives (AND $7500 Fed rebate) to move Volts off the lots. I know because I was crosshopping Volt and Prime and followed the prices closely for quite a while.
    And the above in no way disses the Volt as a car and especially as an engineering achievement; but making a great car and making a profitable car is two different things.
  3. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    With the added weight, it also wouldn’t get quite as good MPG nor MPKWh either.
    #43 mr88cet, Mar 9, 2020
  4. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    He knows Prius Prime was only available in one-third of the country, making the absence of supply a distortion of demand. He also knows that GM was all about conquest sales, not trying to actually change support at their dealers. So, the comment was misleading at best.
    Reality is, the difference between goals & approaches was so profound, there is no constructive means of comparison.
  5. Trollbait
    12,800
    Getting Primes off the lot also took large incentives, whether from the feds, states, and/or Toyota.
  6. EV Happy
    EV Happy Member
    75
    I probably would do with less hatch space and would definitely give up the fifth seat too. This is all presuming the weight does not increase. I am yet to need that fifth seat in this car.
    pghyndman and bisco like this.
  7. Trollbait
    12,800
    Where the Prime was readily available was some of the most populous areas of the country, and where hybrids and plug ins sell well. When the PiP was limited to just CARB states, Toyota's statement was that represented 60% of the hybrid market. Many posters here made the effort of buying out of their home state didn't have any Primes available. More so than did for the PiP.
    Toyota is claiming the Prius Prime is nationally available. Sales success needs product available for buyers. How is it Toyota's competitors' fault when they fail on that? Granted Gulf and Southeast Toyota might be working against them(so much for changing dealer support).
    The Volt had a roll out period in which it wasn't available across the country; all new cars do. When first year sales didn't reach 8,000, did critics cut them slack? Its second full year sales was 23,451. The Prius Prime's was 27,595.
    If Toyota wanted to make an affordable 50 EV mile Prius Prime, they could.
    #47 Trollbait, Mar 11, 2020
  8. smyles
    332
    229
    US
    2020 Prius Prime
    An affordable 50 EV mile Prius Prime would cost the same as Volt - around $40...45k, - and would sell as badly as Volt (and Bolt).
  9. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    I refuse to believe that GM outclasses Toyota by such a large margin. How can they ship a 250-mile battery in the Bolt EV for $15,000 LESS than Toyota could ship a battery 1/5th that size?
  10. john1701a
    12,840
    5,312
    58
    Low volume sales at a loss isn't anything to brag about.
  11. PiPLosAngeles
    1,551
    724
    That was the Prius in the beginning too. Perhaps Toyota should have abandoned that effort?
    fotomoto and Trollbait like this.
  12. PiPLosAngeles
    1,551
    724
    According to this article GM is losing about $7,400 per Bolt. That's still significantly less expensive than $50,000.
    Also, I think the poor sales of the Bolt are because it's a GM product. I'd purchase an exact carbon copy of the Bolt if it was made by Toyota in a minute, but from GM ... not a chance.
    bisco and Prius Maximus like this.
  13. john1701a
    12,840
    5,312
    58
    23 years ago... Different time. Different audience. Different goals.
  14. mr88cet
    2,313
    1,335
    Austin, TX
    Sorry if I lost the context here, but are you comparing against the Prius Prime?
    If so, then last I checked at least, list price at least on the Bolt was on the order of $36-42K, as opposed to $28-34K for a Prius Prime.
  15. PiPLosAngeles
    1,551
    724
    I'm comparing what it would cost for a theoretical Prime with a ~18 kWh battery. If Chevy's and Tesla's battery costs are any indication, it should only cost about $1,500 more. When you factor in the Federal EV credit, the car would be $1,500 less than the current Prime because it would qualify for $3,000 more in tax credits.
  16. smyles
    332
    229
    US
    2020 Prius Prime
    ... right, because stuffing extra few hundred pounds and cubic feet of batteries in a compact car is that easy.
  17. PiPLosAngeles
    1,551
    724
    Under the rear seat is pretty much empty space.
    Trollbait likes this.
  18. mr88cet
    2,313
    1,335
    Austin, TX
    Ah.
    It would have to go into the floor, which would make it a ... very different vehicle.
    #58 mr88cet, Mar 11, 2020
  19. bisco
    52,763
    Volt fit 50 miles in the floor of a totally new design.
    Toyota hasn’t shown the inclination to make a brand new vehicle from the ground up.
    Heck, they had to shoehorn 25 miles into the Prius
  20. mr88cet
    2,313
    1,335
    Austin, TX
    Volt or Bolt? Since you say “50 miles,” you presumably do mean the Volt.
    The Volt had a T-shaped battery mostly inside the cabin space. The Bolt, which has more of a crossover form factor, has batteries in the floor.
