What product is best for a glossy, wet tire look?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GreenGuy33, Dec 31, 2009.
  1. GreenGuy33
    GreenGuy33 Active Member
    534
    29
    Rhode Island
    What's the best product to get that wet, glossy look on the sidewalls?
  2. risingsun
    risingsun seeker of the way
    186
    30
    Prescott, AZ
  3. jim256
    jim256 Member
    317
    69
    Eastern NC
    Agreed but if he wants "wet and glossy" look I'm afraid he'll be disappointed. 303 for sheen and protection, which is what I want, but it's not one of the high gloss products, thankfully
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Armor All makes products in the Extreme line, I have an aerosol Extreme spray can of tire gloss (they had a 3 pack of it at BJ's Wholesale a while back) and it leaves a very very wet shiny look on the tires. Just don't overdo it or it does sling onto the car a bit once you get moving fast.
  5. Wix
    Wix Junior Member
    Cullman, AL
    Used most all resources and this is the best and easiest solution. Don't even have to put in elbow grease. :)
  6. Joe166
    Joe166 New Member
    720
    96
    South Florida
    Any of the tire shine products fairly well shines up the rubber. There are wheel covers you can hold over the metal part of the combination while you are spraying on the shiny stuff so that the wheel doesn't get greasy and gather even more dirt than usual.
    The best thing to do is spray the cheapest product you can find on sale onto a tire sponge and then rub it around the tire surface. Lets less product build up so you can spare the sides of your car from the black goop.
    Some of the better products don't fling off, but they usually don't pop out at you as really shiny, either.
