What range do you get on a fill up
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by fopoku2k2, Aug 1, 2017.
  1. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    What range do you guys get on a fill up?
    I usually get around 430 miles on my 2010
    MI 5s ?
  2. blackcherrypri
    blackcherrypri Junior Member
    US
    Right now I'm getting around 450 before I get down pass 0 blinking pip. Usually I drive less than 20 miles past zero before the fillup. Flint mi.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Just filled up tonight and put 9 gallons in for 480 miles:).
    Had 2 PIPs left when I pulled into the Arco.
    2010 Prius II with 159 k miles(y).
  4. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    440 with one notch showing on dash board.
    Raytheeagle likes this.
  5. Lightning Racer
    Lightning Racer Active Member
    239
    321
    Anchorage, Alaska
    613 miles on the last tank.
    I usually keep track of when the last pip on the gauge starts blinking, which means about 2.7 to 3.0 gallons left. 2.7 more gallons would be to the stated capacity of 11.9 gallons, and 3.0 would be to 12.2 gallons, which is what Bob Wilson found when he ran his Gen 3 dry on purpose. If I'm driving around town, where I don't worry about where the closest gas station is, I will typically fill up about 2 gallons after that last pip starts blinking, estimating my usage by looking at the mpgs for those last miles. My last several tanks have taken 11.2 gallons, which I don't consider pushing it because I'm monitoring, and it's still 35-50 miles range left. If I'm on a road trip, I'll fill up much earlier.
    fopoku2k2 likes this.
  6. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Cool. Then mine isn't that bad. I thought I was being short changed
    MI 5s ?
  7. isano.chan
    isano.chan Junior Member
    Indonesia
    Range get 1.000 km easily on a full tank
    SM-N9208 ?
  8. marlinsmobile
    marlinsmobile Active Member
    106
    131
    Sandy Springs (Atlanta), GA
    Man, you guys are killing it mpg-wise! I average only 383 miles per fillup, but I usually refuel with two pips remaining. I'd probably be around 420 or so if I were more willing to live on the edge :)
    My Gas Mileage Dashboard
    Jkan2001 likes this.
  9. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    You do a fill up per week? Damn!!!!
    MI 5s ?
  10. bisco
    52,773
    if i don't plug in, i can get 6-700 miles, depending on the type of driving, and weather.
    jerrymildred likes this.
  11. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    How I envy you guys with plug in option ...
    MI 5s ?
    jerrymildred and bisco like this.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    I was going to suggest the they'd better not ask you. LOL! I've not yet driven a whole tank without plugging in, but I would guess close to 500 miles. If I ever get to take a road trip, I'll find out. I'm at a record rate now because I haven't had to outdrive my battery as much as usual. I'm still showing a half tank remaining and have gone well over 500 miles. Showing about 127 mpg on the display. But Bisco blows that away on a routine basis.
    But I still want a Prime. LOL!
    Neohippy and bisco like this.
  13. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    What's the difference between what you have and a prime?
    MI 5s ?
  14. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    My next Prius will be a plug in, especially with my driving routes.
    Earlier this week, I went 520 miles before filling up. I never come close to using the entire tank- even when I get the warning light, I still have 2 gallons left.
  15. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    I'm also buying a plug in next. I might just wait and buy @bisco's
    MI 5s ?
    Raytheeagle and bisco like this.
  16. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    I own both. I drive the PIP and the wife drives the 2011. I'm averaging 80mpg vs her at 48 right now. It's summer so both or our mpgs are down. Amazing how much better the plugin does
  17. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    620 miles? Something like that. That was the one time I drove my Gen 4 (not a plug-in) all the way until the fuel light came on. Now I just fill up when I'm at 1/2 remaining. The fun is over. :LOL: Now I just drive it. Don't even check the mpg anymore. It's been a great car so far.
  18. bisco
    52,773
    are you back from africa?
  19. jerrymildred
    11,517
    14,164
    Tampa, FL
    Quite a bit. Prime has more than twice the battery range, better efficiency in both hybrid and electric modes, lots more safety features and other bells and whistles, more horse power, better handling, quieter. I haven't driven one, but I would expect the sense of upgrade from mine to a Prime would be even more than when I changed from a Gen 2 to the PiP.
    padroo, fopoku2k2 and CoastRider like this.
  20. bisco
    52,773
    prime has 4 seats and less hatch space.
    fopoku2k2 and jerrymildred like this.
