What recall is this article talking about?
Discussion in 'Gen 4 Prius Main Forum' started by mistermojorizin, Jul 2, 2019.
  1. mistermojorizin
    mistermojorizin Active Member
    310
    137
    usa
    2019 Prius Prime
    Toyota expands Prius recall, reveals up to 20,000 hybrid inverters failed - Los Angeles Times
    What recall for 2018 Prius models came out last week on June 2019?
    52,803
    gen 3, 2010-2015
  3. mistermojorizin
    310
    137
    usa
    2019 Prius Prime
    Please read the quote again. It says "Prius models made in 2018."
    52,803
    how far down?
    found it. i think he meant 2015. the original was for 2010-2014
    why would they skip 15,16 and 17?
  5. mistermojorizin
    310
    137
    usa
    2019 Prius Prime
    I put a quote from the article in my OP. You can ctrl+f through the article to find it in the article itself if that's what you mean.
  6. bisco
    52,803
    found it, see my edit above
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Car and Driver reported it too - but only quoting LA Times. But they concluded "While complaints like Hogan's can compel NHTSA to launch investigations and audits into ongoing recalls to determine if a remedy is working, there is no such case open as of this time."
    It'd be interesting to see the real story behind some of these press reports - is this more a businessman vs TOYOTA issue? - which he's implicated TOYOTA. But I'd wait till there is a response by TOYOTA.
    We've all seen the press give partial, inconclusive or poor reporting in the past.
  8. mistermojorizin
    310
    137
    usa
    2019 Prius Prime
  9. bisco
    52,803
    the problem with this whole situation is the same as the past u/a. the numbers aren't high enough to make toyota do much.
    that can easily be seen here, in the very few complaints of cars dying on the road, compared to the number of gen3 owners here.
  10. Sr5dude
    Sr5dude Member
    58
    55
    Gilroy,California
    Toyota replaced my inverter and harness when it died after the software update
    amos likes this.
  11. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
  12. 3PriusMike
    3,101
    2,421
    Silicon Valley
  13. bwilson4web
    16,515
    This has been going on a long time. Thanks for the update about the trial.
  14. mistermojorizin
    310
    137
    usa
    2019 Prius Prime
    Yea it's the prius C and its not related to the inverter.
    "Toyota said it is also recalling the 2018 Prius C to fix DC-DC converters on about 500 cars in the U.S., which is unrelated to the inverter recalls. "
    Toyota Prius Stalling Problems Continue - Details of Dealer Lawsuit
    My question for the gen 4 crowd is, how similar is this DC-DC converter on the C as compared to the gen 4? Is the C a variant of the Gen 4?
  15. alanclarkeau
    7,045
    7,593
    My understanding is that it's very different - though the principle is the same. @Tideland Prius might know more?
    mistermojorizin likes this.
  16. mistermojorizin
    310
    137
    usa
    2019 Prius Prime
    I think you're right. A quick read on wikipedia seems to indicate the hybrid tech in the C is more similar to the 3rd gen Prius. The platform is similar to the Yaris, but that doesn't make a difference when it's a part of the hybrid system being recalled.
  17. alanclarkeau
    7,045
    7,593
    Yes, my belief is that PRIUS c was a shrunken but similar version of the Gen 3 drivetrain in a body based on YARIS platform - and has only had styling etc changes since about 2012. Very good seller - particularly in Japan.
    Gen 4 PRIUS was a fairly major re-design of Gen 3, with almost nothing untouched, both body and drive-train. The only similarity is that the tyres are still black:rolleyes:.
    krmcg likes this.
  18. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,804
    1,170
    Auburdale FL
    Can't find tires for my Benz.
    alanclarkeau likes this.
  19. Tideland Prius
    16,674
    Hmm I'm not sure. I'll pass the buck to @Elektroingenieur . Is the Gen 4's DC-DC inverter the same as the Prius c's?
  20. alanclarkeau
    7,045
    7,593
    Looks like I can get them for Dad's (granddad's originally) Austin - not cheap, double what a PRIUS tyre is:
