What relay under the hood will disable car
Discussion in 'Gen 2 Prius Main Forum' started by terramir, Aug 2, 2024.
  1. terramir
    terramir Member
    319
    51
    Los Angeles
    Ok, one of my keys was stolen they already stole stuff out of my car.
    Until I can get the key deleted what relay can I remove from under the hood in order to stop the car dead I want something reversible quickly I wish I could disable the doors as well but getting to the rear sucks once the battery is disconnected, a small fuse is too small to take out.
    terramir
  2. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    This is a generation too so if they've stolen one of your complete remotes or key fobs then they have the metal key to get in your car no matter what you do to it right? Are you banking they don't know that there's a metal key in the key fob? Or how does this work out in our minds? What are we going to disable on the vehicle that's not going to allow this person that has the electronic access code and the physical metal key to operate the lock in the driver's door???.
    Brian1954 likes this.
  3. terramir
    terramir Member
    319
    51
    Los Angeles
    Dude if he steals my stuff inside ok I just don't want him to be able to drive it , I don't know if he knows about the emergency key, but anything that makes it harder the better. Gonna order a key and lock off eBay hopefully then it will keep him out 35 bucks we'll spend.
    terramir
  4. ChapmanF
    19,025
    Besides eBay, I think you can also buy the replacement lock cylinder kit right from Toyota and it's not much money, comes with two precut metal keys. Swapping the cylinder in the door is a very easy job (nothing at all like the old days where to rekey a car you'd have to take apart all four doors and the steering column and the trunk).
    And as long as you still have one fob that's registered as a master, you can use the "forget all fobs except this one" procedure right away.
    There must be several choices for fuses to pull or other connectors to undo that would be equally effective at keeping the car from going anywhere.
  5. terramir
    terramir Member
    319
    51
    Los Angeles
    How do I do this?
    Is there a chicken dance for this???
    I can't get in the body ECU with the cable I have neither the immobilizer or the sks ECU.
    I know how to replace the door lock I did this when I replaced the door after a semi backed into mine. eBay was $35 with one key I can get another one cut later. New one is cheapest online like $80
    #5 terramir, Aug 2, 2024
  6. ChapmanF
    19,025
    Not sure about a chicken dance. Gen 1 had one and I used it, but gen 2 I'm not sure. If your dongle won't connect, that might be an obstacle.
  7. terramir
    terramir Member
    319
    51
    Los Angeles
    Yeah I need to find that list with working dongles the open2.0 one is like $169 too much for me I wouldn't mind spending 60 bucks for a working cable . I disconnected the battery for now and I tied a USB cable to the braided fishing line so if I need to go somewhere I can reconnect it and use the emergency key to get in. I do not know where the file is with working dongles, I tried searching with Google no dice.
  8. ChapmanF
    19,025
  9. Tombukt2
    13,864
    2,519
    Durham NC
    Guess you could pull an EFI relay or something like that but I mean if these people stole your key fob seems to me they must know you pretty well where the key fob is been in your apartment you keep them both in your car? I mean whatever something seems like they would have taken the car if that was the end game I mean that is a felony you know if you're going to commit a felony like that you might as well steal a nicer car seems to me or you're going to come back and get some electronics and laptops and stuff that's left in a given car because you have access which I don't ever leave stuff like that in my car so you know not much of an issue.
  10. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Homeless people got to eat bro. Don't be stingy
  11. pasadena_commut
    pasadena_commut Senior Member
    3,067
    952
    Southern California
    You could pull a couple of relays (fuel pump would be good) and take them with you. If you hide them in the car the person you are worrying about might find them and reinstall them.
    At this point I think I wouldn't bother with the relays though, instead go with something like "the club" and place a device like an apple tracking tab on the vehicle.
    The car does have a built in alarm, disabled by default. If you turn that on I think that maybe it will go off when they try to use the emergency key (after the fob has been disabled). All that said, if they want the stuff in the car they will just break a window, grab it, and run.
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    A very easy thing to do is remove the 15 amp AM2 fuse in the underhood fusebox. Try it, you'll like it.
  13. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    In addition to removing the AM2 fuse, don't leave the AM2 slot empty, install a blown 15A fuse in its place. You don't want to make it too easy for the toerags to work out what's wrong assuming they have the luxury to troubleshoot.
    landspeed and pasadena_commut like this.
