What runs the AC in a PiP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Mayank Jain, Apr 23, 2018.
  1. Mayank Jain
    Mayank Jain Member
    106
    70
    Cupertino, CA
    Hi everyone,
    I am loving every minute of driving my PiP 2012 advanced.
    I'm curious to know, when in EV mode : if the AC turns on, what powers it?
    It's definitely not the EV battery as i cannot see it moving down as the AC keeps running. Neither can i see the engine turning on in the display. 12v battery is also not assumingly sufficient to drive the AC. Then what is running it?
    Can someone explain it to me :)
    Thanks!
    #1 Mayank Jain, Apr 23, 2018
  2. jm64
    jm64 Junior Member
    25
    24
    Bay Area, CA
    2014 Prius Plug-in
    It's the EV battery, if you sit with the AC on long enough, you'll see the EV range go down. If you have no EV range left, and sit with the AC on, you'll see the hybrid battery indicator go down, somewhere below the half way point, the engine will run for a while to charge up the battery a little to continue to run the AC.
  3. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    Yes, it's definitely the traction battery. You can see the accessory power load via an OBD-II reader, and I've seen that go up to around 1kW or so when the compressor is running.
    Data Daedalus and Mayank Jain like this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    It's the same as the regular Prius; the HV battery.
    Watch what happens to your predicted EV range when you hit the AC Auto button. Mine, for example, when I start out with AC off, might predict something like 11.9 miles. The moment I turn on the AC, it will drop to 10 point something. It seems to be about 10%. Turn off the AC and the expected range goes back up.
  5. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    If you want detail, jack Kelly at Weber Auto has this video on the gen 2.
    Powering the A/C compressor is discussed from 15:10 to 17;00.
  6. Mayank Jain
    Mayank Jain Member
    106
    70
    Cupertino, CA
    Thank you everyone, I'll experiment with this when i drive again. Cheers!
  7. QuantumFireball
    420
    269
    Ireland
    If you leave the car in "Ready" mode parked up with the AC on, you will certainly see the EV range go down after 10 minutes or so.
  8. bisco
    51,155
    a better way to know if the engine is running is to watch the mpg gauge. it will be fluctuating, unless you come to a standstill.
    my battery definitely drops with the a/c on, but is hard to notice when moving, as it is dropping anyway.
  9. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    Yes, the Traction Battery supplies the power, however I doubt that it directly runs the A/C. What it does is to provide 12 volt charging to run all the 12 related devices, computer, lights, displays, seat heater, etc, and A/C. Remember the discussions about using the car as a 110v source using a 12 volt inverter. The A/C does not run on the Traction Battery 600v (?) output :)
    Mayank Jain likes this.
  10. QuantumFireball
    420
    269
    Ireland
    According to this thread, it's running at around 200V from the DC-AC inverter:
    How many volts does the GEN III AC Compressor run at? | PriusChat
    12V DC wouldn't be much good for running an A/C compressor. It's probably an AC motor driving the compressor - similar to a domestic A/C unit, which would typically run on 220-240V AC mains power. This would explain why non-hybrid cars still have belt-driven compressors, as there's no readily available high-voltage supply with sufficient power to drive it electrically.
  11. Mayank Jain
    Mayank Jain Member
    106
    70
    Cupertino, CA
    When driving on AC in EV mode, i saw my cruising miles number drop even when engine was not running. I saw this when in the parking lot when we were parked with AC on in EV mode. I'm taking it the cat today again and will verify this behavior.
  12. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    In Gen 4 I believe it gets the 207 VDC from the HV Battery and inverts it to AC in the Compressor housing. (in Gen2 the DC to AC intverter was part of the Big Inverter)
  13. jerrymildred
    11,517
    14,137
    Tampa, FL
    Yeah, if that compressor had to run on 12V, the wires would have to be huge to handle the enormous amperage required to deliver enough power.
    Data Daedalus likes this.
