What services you need and what you don't
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by galaxee, Feb 22, 2007.
  1. rusty houndog
    rusty houndog mountain rider
    152
    Buffalo, Wyoming
    Re: What services you need and what you don't
    Periodically, these directions to remove the "Maint Reqd" light need repeated.
    1. Hit "Odo/Trip" button until the display says "ODO" and shows odometer
    (even if you started on odometer, you have to do this).
    2. Power down the car.
    3. Press and hold the ODO button.
    4. Keeping your feet OFF the brake, press the Start button twice and wait
    while the ODO display does a little dance.
    5. When it's back to showing your odometer, release the ODO button.
    Simple as that, but follow the directions exactly! You must cycle the ODO display first. You must keep your feet off the brake. You must keep pressing the ODO button continuously.
  2. lkeene
    lkeene "Manymiles"
    Oroville CA USA
    How much is and at what which point does one need to replace the expensive hybrid battery? I have a 2005 Salsa Red with 88,635K on it. I've lost a few mpg since it hit 70,000K and am starting to obsess on this battery thing.
  3. Patrick Wong
    18,210
    6,510
    The 2G traction battery MSRP is around $2,200 and you will have to pay a few hundred $s in labor charges. The point when you will have to replace the battery is when your instrument panel looks like a Christmas tree; specifically you will see a traction battery warning icon appear in the MFD.
    There are a variety of reasons why your fuel economy might drop: dragging rear brakes, bad wheel alignment, improper tire inflation, installation of new tires, change in gasoline formulation, etc.
  4. jimdoyle56@gmail.com
    [email protected] Junior Member
    Bethesda, MD
    For Galaxee, her hubee, and others who contribute knowledge and experience:
    I just got a friendly letter from "Service manager" at my Gaithersburg, MD dealer (Fitzgerald Auto Mall, which I have liked) inviting me to get a $990 30K service!!!
    It includes "vent service" ($40), "top engine cleaning" ($180), "4WA" ($100) and "B Valve Pack" ($270)
    What in the world does all that even mean? I know from Galaxee's great post that most of this stuff is more appropriate at 100,000 miles or when the car is acting sick. Neither is the case. It's an '05 with 28K on it and nary a problem so far except the tires are wearing out a little faster than I would expect.
    Anyone: HELP!
    Jim Doyle
  5. Patrick Wong
    18,210
    6,510
    Hi Jim,
    Refuse your dealer's suggested services. Refer to your owner's maintenance book or else find the 30K mile maintenance schedule on toyota.com if you want to avoid paying for unnecessary service.
  6. jaw444
    jaw444 Member
    281
    27
    San Fernando Valley CA Sherman Oaks area
    On Thursday my 07 passed the number of miles that the dealer had set it for at the last service and the intermittent "Maintenance require" became a constant one, and i plan to take it in for its service tomorrow.
    i plan to have done only what the Toyota maintenance book says it needs, regardless of what the dealer might suggest.
    My car's gas mileage seems to be gradually going down over time, just slightly, but the overall trend is down. It will stay around one level, like 41.3 for weeks. Then it will go down to 41.1 and stay there for a long time. It doesn't seem to make a difference if i strive to minimize gas use by using the display feedback while i'm driving and avoiding accelerations. If it's going to go down, it goes down. Then, sometimes it will come back up even though i'm not trying to get it to.
    Is there any special things that i should ask to have checked that might affect gas mileage, anything that might need replacing? I drive in ordinary conditions; the main condition i drive in that is hard on good gas mileage is a frequent fairly long drive in gridlock traffic on an upward incline, several times a week. I would guess i might need the cabin air filter replaced or cleaned, or something like that.
    I also worry about the way my battery discharges, going from 6 or more bars to 2 purple bars in less than 5 minutes when i'm parked and idling with the AC and radio on. I understand those things will drain the battery, but that fast? I'd say not more than 4 minutes.
    Also sometimes when i'm driving up hill and accerlating, i notice the bars on the battery level indicator sometimes go down. Is that normal? Or does it need checking?
    Could any of this be related to the parking brake? I'm not sure that my parking brake holds the car securely enough, i seem to have to press it down pretty hard to keep it from rolling.
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    No clue, but I'd guess they use a feather duster on the A/C vents
    Never heard of it. Either they use a rag to wipe off the top of the motor, or they *might* claim to squirt some stuff into the intake to clean out carbon deposits. There should be minimal carbon deposits, not enough to make a difference in how the motor ran
    Beats me. Four wheel alignment?? If so, it's a lie, as the Prius rear beam axle is normally considered not adjustible, at least not by official Toyota means
    I do not know. B as in bulls***?
    It's quite apparent that some dealerships will try to make money in the service bays, if they can't make money selling the car to begin with
  8. jayman
    13,439
    641
    Winnipeg Manitoba
    If compared to new, perhaps the front end needs an alignment. Check tire pressures. If compared to the last month or so, increased use of oxygenated fuels can sometimes cause fuel economy to decrease, and there is nothing you can do about that
    The SOC change sounds like normal driving to me
    From your description of the parking brake, it doesn't sound like the shoes are dragging. Just the opposite. Wouldn't hurt to ask the dealership how much to adjust the parking brake
  9. jaw444
    jaw444 Member
    281
    27
    Thanks for the reply, feedback, it will help me to not set my self up for asking for unnecessary repairs.
    The gradual decrease in MPG is neither since new nor since last month. I got the car in January of this year, january 2. It was at around 43-44 mpg when i got it, and it just gradually went down over weeks, 1/10 of an MGP a week or so. Over the 5 months I've had the car, it's down to staying around 41.1 for the past few weeks. The long term trend is going down. It's never gone up.
    the one exception is that about a month and a half ago, there was a sudden dramatic drop in MPG, to 37.8 or something like that, overnight, for no apparent reason. It stayed at that level for a day or two. Then it steadily returned to 41.3 or so, whatever it had been at before. Within a couple more days it was back up. And then, has gradually gone down, i can't get above that level. I guess it must be my driving habits/needs combined with driving conditions.
    Are there threads on this forum somewhere that have a list of tips or guidelines, or a summary, of things to do to try to maximize MPG? I've used the Search engine but haven't had success.
    thanks
  10. rusty houndog
    152
    Buffalo, Wyoming
    Your frustration with Los Angeles traffic would be my first suspect for radical changes in mileage. My mileage started around 48MPG and now hovers around 52MPG. There are times it drops but that's when I shove my foot through the fire wall going up mountains.
    http://techno-fandom.org/~hobbit/cars/mpghints.html
    Possibly you also shove your foot through the fire wall, occasionally, to catch up with traffic waves? Lots of self control is needed for good gas mileage in urban traffic.
  11. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Top engine cleaner is a compound that's supposed to remove carbon from the intake system and pistons. Either it's added through the air intake, or as a gas tank additive. Obviously $180 is way overpriced for this -- get a can of injector cleaner and put it in the tank if you want and save $170.
  12. jdouge
    jdouge Junior Member
    16
    Coastal California
    After lurking this article for a few years and finally cracking the 60k barrier (2007 TE Prius), I set out today to find a tech for PCV valve replacement and a CVT drain and fill -- basically following galaxee's (much appreciated) recommendations on the valve, and the subsequent research (consensus?) on preventively changing the CVT fluid generously submitted later in this wonderful thread.
    The dealership was a joke, as expected: $110 just to look at the car. "But I already know what I want done." Well, we can't give a price until we have the car in here and look at it. So what time would you like to do that? "Um, I'm going to call around." Well, you know, if you have someone that isn't a certified Prius tech work on it, you'll void the warranty. "Um, no. All of the maintenance to this point has been by my regular mechanic or by me. These two items I'd like to have a tech do, though." Okay, when would you like to bring it in. "Thanks, I'm going to call around." Alright, sir . . . CLICK.
    I found two independent shops with Prius techs. The first: The Prius doesn't have a PCV valve! "Um, actually it does. I've seen pictures of how to replace it but don't think I can do it myself." Oh, you're right, it's way up under some contraption. Listen, let me save you some money, I've never had anybody do that to a Prius, and if I did it, I wouldn't even know what to charge you. "Okay, how about a CVT drain and fill?" A drain and fill, not a flush? That's $85 fluid and labor. "Okay, thanks."
    The second: $140 for the PCV replacement and $115 for the CVT drain and fill, but we use a synthetic fluid, not Toyota's. "Does that fluid meet Toyota's warranty requirements?" Yes, it's a common, non-generic [he used a technical term, not a brand-name here] fluid, and cheaper than the Toyota spec. "Okay, what if I want the Toyota fluid." Hmm, we don't stock or order that. "Okay, let me call you back."
    So . . . sorry for the long post, but what now? Certainly no perfect options.
    My gut says get the $85 drain-and-fill, and wait until 100k (I have the extended warranty until then, in case the PCV valve does fail, Toyota's on the hook for whatever happens rapidly after that) for the PCV replacement.
    Other opinions from others with oodles more knowledge than my gut on this case appreciated!
  13. Patrick Wong
    18,210
    6,510
    I agree with your decision to get the transaxle fluid changed for $85 as long as Toyota ATF WS is used and not some substitute. That fluid costs ~$8 per quart at local dealers here and you need 4 quarts.
    I also agree with your decision to put off replacing the PCV valve until 100K miles. When I recently changed my PCV valve on the 2004 at around 70K miles the old one looked good (based upon shaking it, did not appear to have a significant deposit buildup.)
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    As far as the PCV valve, I'm going to suggest that operation in a warm climate that never sees cold winter temps, especially down to -40, you're really not going to have to worry about the PCV valve that much
    Operate the motor in a cold winter climate, there will be a lot of vapor introduced through the PCV valve. That will eventually gum it up. But in a warm climate, I wouldn't worry about it
  15. jdouge
    16
    Coastal California
    I'll take the kind advice and get the CVT fluid changed (with Toyota's spec fluid). The car's never been at (not even in the garage, or parked at a trailhead) or below freezing, much less operated at temperatures that cold. So . . . PCV at 100k it is!
    Thanks for the help, folks.
  16. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    How about cold weather but long drives (~20 miles)? Would it still gum up in this case? Thanks! :)
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    There will be a lot of vapor in the PCV system, even after a long drive at bitter cold temps. Over the years, various car makers have had various TSB's and recalls, as related to operation in bitter cold temps
    What usually happens, the PCV will ice up, the TB will ice up, EGR (Does not apply to Prius) will plug, etc. The fixes have included redesigned PCV valves and tubing, different TB's, different EGR valves, etc.
    I always thought manufacturers tested their vehicles in places like Alaska and the North West Territories. I guess not
  18. bibs
    bibs Junior Member
    cape cod
    I'm up for the 40K so this was quite valuable
    many thanks
    Allan (aka bibs)
  19. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I just dropped Silver off at the dealer for his 65,000 km service, and one last look by the pros before the warranty's done. I'm giving the local guys another chance - we'll see how they do at following the Prius list instead of the generic one.
  20. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    ...Not so good, it turns out. Two days and $400 later, they couldn't find the noise I'd taken it in for, did things I asked them not to, and didn't do things I had specifically requested. The next dealership is further away, but it's worth the inconvenience.
