What services you need and what you don't
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by galaxee, Feb 22, 2007.
  1. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    you can clean and adjust your rear brakes at home. there is an adjuster in there like with many rear drum brakes.
    you don't want to do any flushing of any coolant in a prius.
    at 50k our throttle plate was pretty clean. and we're fairly demanding of the car.
    brake pads are going a very long time- most early replacements involve severe rotor rust due to salty air/roads.
  2. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    Re: What services you need and what you don't
    Heh, I noticed a few front disk rust stains already on my new Prius, perhaps from rain or car washing. Wonder if I should give the brakes a few good jabs every week or day just to keep them clean ?
    We have salted roads in winter. Guess there's not much I can do but wash the disks off every few days or every weekend ?
  3. Patrick Wong
    18,214
    6,531
    Hi Michael,
    After you wash the brakes, it would be good to drive the car at 35-40 mph, then shift into N and brake, to dry the disks.
  4. LRP114
    LRP114 Little Lou
    26
    Silver Spring, MD
    Galaxee, please ask your "expert" husband two questions for me.
    1) I am not sure if you posted it, or if someone else did, but the person wrote that it is a good idea, even at 5000 mi intervals, to use Mobil 1 oil, but then went on to say: if using Mobil 1, be sure to use the (over-sized) Toyota brand oil filter. Is there any reason to use the Toyota oil filter, vs any name brand, like Mobil, or Fram?
    2) for the Prius, is there a measurable difference in synthetic oils between brands, like Mobil, Pennzoil, Quaker State, Shell, etc? I have been told (at auto parts stores) that Mobil is the "best" and at another, that Mobil was one of the worst name brand synthetics, but because it was heavily marketed, it is often used.
    I, like so many others, REALLY DO appreciate your informative and experienced opinions on such matters.
    Little Lou:p :p
  5. kathyb
    kathyb New Member
    53
    Brooklyn, N.Y.
    I'm taking my Prius in for the 6 month check up. Only have around 1700 miles on it.
    What should be done and what is not necessary.
    I'm a total amateur as this is my first car:p
    I'm taking into the dealer that I bought it from.
  6. bruceha_2000
    bruceha_2000 Senior Member
    3,057
    302
    Northwest VT
    2018 Prius Prime
    Um, nothing is necessary unless you have some pretty harsh driving conditions.
    Maybe new wiper inserts (tell them INSERTS!!!!) if your car lives outside and they are streaking even after cleaning them. They do degrade in the sun.
    Do you only have 1,700 miles because you rarely drive, or you only drive 9 miles a day? The latter would be a fair number of cold starts per mile.
    Unless you have problems, at MOST SPECIFY exactly what as listed in the service manual.
    For 6 months/5,000 miles that is:
    1. Change oil
    2. Rotate tires
    3. Visually inspect brake linings/drums and brake pads/discs
    At 1,700 miles, you don't need to do anything other than the oil change (And only for warranty coverage ). I wouldn't bother with the tire rotation myself. It costs money and there isn't any reason to rotate them just because 6 months have passed. Of course, if they are going to inspect the brake pads and drums/discs, they have to take the tires off anyway so I suppose there wouldn't be much if any extra cost to rotate. However, unless you stop by slamming on the brakes rather than using regen to stop (down to 8 MPH), they probably couldn't tell if there was ANY wear on the brakes at 1,700 miles.
    Don't let them talk you into 'we always do ....' extra cost items.
  7. galaxee
    9,810
    471
    MD
    hi Lou-
    brand choices are absolutely up to you.
    we have used several different oil filters- if we can't get to the dealership and are changing the oil that day, we've used non-oem filters without trouble. many people do, it's not a big deal. the general rule is to avoid fram.
    when it comes to oil, again it's your choice. DH spent most of his time fixing the mechanicals, not recommending oil brands to use, so he's not a well read expert on the subject. we use mobil 1 and so do many others.
  8. racerbob
    racerbob Member
    138
    S Florida
    Galaxee,
    Here is a good one. Something most owners don't even know about. Has your husband checked many 2nd gen valve clearances, and if so, how many were off enough to recommend going through the labor intensive camshaft removal and follower replacement? Were any found to be dangerously tight?
  9. galaxee
    9,810
    471
    MD
    valve clearance... heh... we've had this discussion. in general toyota valves really don't really need to be adjusted.
    as a policy, he only adjusted valve clearance in toyota engines he already had torn into for other reasons- rebuilds mostly. and they were usually within or very close to spec regardless of miles on the engine.
    if anything, they tend to loosen up over time rather than tighten.
  10. racerbob
    racerbob Member
    138
    S Florida
    Thanks, That's what I wanted to hear. Normally, I would check any engine with solid lifters after break in.
  11. Patrick Wong
    18,214
    6,531
    Hi Bob,
    At ~60K miles I checked the valve clearances on my 2001. Out of 16 valves I recall that 4 or 5 had very slightly greater clearances than spec; while none had smaller clearances than spec.
    However I decided to leave well enough alone after contemplating the work required to remove the two camshafts, preserve camshaft timing when reassembling, etc.
  12. turnbowm
    turnbowm Junior Member
    So. Calif.
    2. clean/adjust rear brakes
    only if you have drums (obviously in the prius, we do). ideally, for optimal brake life and performance, this is probably a good idea every 30k miles. for other cars, 15k a better idea. when you hear a tone out of the rear brakes, it's either time to change the brakes or have them cleaned/adjusted. if it's not done, you can see an increased brake wear rate (front and rear). possible complications are problems due to technician error- adjustment extremely tight can overheat a bearing. otherwise noise, brake chatter, or increased wear rate and glazing if not properly adjusted.
    It's my understanding that the rear brakes (drum) have a self-adjusting mechanism. If that's the case, there would be NO reason to manually adjust them. Also, the regenerative braking results in very little actual brake wear since they're only used at low (<15mph) speed or in panic stop situations. As such, I would expect them to remain MUCH cleaner than in a conventional (non-hybrid) car.
  13. galaxee
    9,810
    471
    MD
    they are indeed self-adjusting. however, as we've demonstrated in the past, this mechanism is not perfect. a while back, we checked the rear brakes and one side was in perfect adjustment while the other was way out and required manual adjustment.
    brake dust accumulation is a very minor factor, yes. but periodic cleaning is not a bad idea, and a 30k interval isn't exactly frequent.
  14. schoonie
    schoonie Junior Member
    NE Pennsylvania
    Thanks Galaxee. You've confirmed suspicions for me and many others I'm sure. How about the cabin air filter change frequency?
  15. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    That would depend on how dusty things are. Personally, I feel the recommended change interval is *very* optimistic. With my Prius and my FJ, they are usually ready to chuck out at under 6 months
  16. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Wow, what a long thread. Too much information, that's for sure.
    I've just taken mine in for its 30K oil change. The dude said my tires are ripe for replacement, so they'll do that as part of my extended warranty. He then asked if I also wanted to do the 30K's Max Menu for $495 (with 10% off if I don't need the rental car.) I told them I'd have to come back another day (so that I can have time to do some research on here first ;) ).
    At this point I'm thinking of going ahead and let them replace the tires (which I assume also include balancing and alignment, correct?) Then at a later time, if I choose to get some other tires elsewhere I'll just trade these in. I've been wanting to get some quieter tires for sometime now.
    Anyhow, to keep things simple, which of these Max Menu 30K services do you think I need and don't need:
    1. Drain and Fill Engine Coolant (if Applicable)
    2. Complete Automatic Transmission Exchange (if Applicable)
    3. Drain and Fill Front and Rear Differentials (if Applicable)
    4. Drain and Fill Transfer Case [what the hell is that??]
    5. Replace Non-Platinum Plugs
    6. Replace Engine Air Filter [actually, I can do this myself]
    7. Replace Cabin Air Filter [same as above]
    8. Complete Fuel Injection Service
    9. Clean Throttle Body
    10. Complete Brake Inspection
    11. Clean and Adjust Rear Brakes
    12. 4-Wheel Alignment [probably done with new tires anyway?]
    13. Complete Battery Inspection [meaning???]
    14. Clean Battery Terminals and Install Anti-Corrosive Terminal Pads
    15. Multi-Point Inspection [meaning???]
    16. Replace Wiper Blades
    17. Install Engine Oil Conditioner
    We live in the Dallas area. Our commutes are mostly in the city. No rough roads, no snow, nothing like that. Any help is much appreciated.
  17. galaxee
    9,810
    471
    MD
    skip
    diy
    skip
    do
    skip
    do, wiper blades conditionally if they need it
    skip!
    you can find more about a lot of these and why/why not in the first post of the thread. really, most of that is awesome for their profit margins but useless or even potentially harmful (see replacing catalytic converter at 85k thread) to you. good luck!
  18. zenMachine
    3,355
    300
    Thanks, Galaxee!
    Need one clarification: you said I do need the Multipoint Inspection. Just what is it?
  19. galaxee
    9,810
    471
    MD
    that's just an inspection all around to make sure everything is ok. it's a good idea to have someone check for things like torn cv boots and other abnormal wear/problems while the car is up in the air.
  20. zenMachine
    3,355
    300
    And if after the inspection, the guy comes to me with a long list of stuff that needs to be replaced/fixed etc., how can I verify? Should I take his word?
