What shall I need to fix?
Discussion in 'Gen 3 Prius Technical Discussion' started by Charles Jhon, May 24, 2018.
  1. Charles Jhon
    Charles Jhon New Member
    Buffalo
    Hi my name is charles, new to being a prius owner.
    I bout a used 2010 prius 3 on this may, and have some minor issues in my car.
    Below is my car invoice about car inspection.
    What shall I need to fix for oil leak? or Should I need to use Lucas 10278 Engine Oil Stop Leak?
    #1 Charles Jhon, May 24, 2018
    52,855
    congrats and welcome!
    i would ignore it all and keep an eye on the oil leak. look underneath to see how floppy the cover is.
    all the best!(y)
  3. Mendel Leisk
    42,347
    @Charles Jhon I'll attach a copy of your invoice, with your personal info cropped out. Due to identity theft issues, I would suggest to delete the invoice you posted, and post this copy.
    52,855
    did you ever find the oil leak?
  5. ohdgj599
    ohdgj599 New Member
    2017 Tesla Model S
    I had the same leak for a long time and attempted fixes like new o-ring did not work. What worked was a new distributor. However I would first attempt just a new shaft o-ring, then the distributor if that is not successful.
    I purchased a new aftermarket distributor and it was fine.
  6. ChapmanF
    19,025
    What sort of car had this distributor of which you speak?
