What size are the larger underbody retainer clips?
Discussion in 'Gen 3 Prius Main Forum' started by Mike72903, Aug 8, 2023.
  1. Mike72903
    Mike72903 Junior Member
    57
    Fort Smith, Ar
    Deciding to change my 2010’s oil/filter myself I discover the underbody panels are close to coming off due to missing retainers. Searching the forum I know most of the underbody panel retainer clips are 7mm. There are a few that are larger. What size are those? Ideally I can find a kit with both sizes.
  2. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    9mm works for me on those random big ones
    CR94 and Mike72903 like this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    You can lookup the Toyota part numbers below which will get you aftermarket equivalents.
    Mendel Leisk and Mike72903 like this.
  4. Eddie25
    503
    213
    MI
    It's also worthwhile to anti-seize all the (2) bolts, most of mine have broke the head off over the years. I drilled them out and use sheet metal screws for now, but I may re-tap them one day.
    PriusCamper likes this.
  5. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    Totally agree... The sooner you can get away from overpriced and quick to fail underbody panel fasteners the better. Even random screws from your junk drawer spun through random parts of the plastic is more reliable than Toyota's lame design standards that are more about lowering costs on the assembly line than lasting durability.
  6. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    Lowering costs AND weight. A few grams here and there do add up.
  7. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    I have an '09 here that somebody took real painstakingly amount of time to put in some very nice stainless steel fasteners Phillips head on one side I'm imagining a washer and a nut on the back they look like about 2 mm very small heads and they did a very good job they are in very ideal places I have pictures they don't like the post here without a bunch of resizing but the people did a really good job It's unbelievable every piece of plastic under this car is in perfect condition not flapping not wind noise nothing It is unbelievable whereas the rest of the car is in okay condition but it's incredible how well they've kept the plastic under pieces especially the far frontal piece that goes from right under the front bumper cover lip under the radiator usually that piece is destroyed by parking curbs and what have you All of these pieces have been very painstakingly remounted with seemingly proper sorted hardware for the long term.
  8. Mendel Leisk
    42,352
    A few thoughts on the engine under panel and its fasteners in the oil change link in my signature*. I’d keep them up, with the stock fasteners, clean and dry.
    I’ve had the panel off completely about 25 times for oil changes, and at least another 5 times for other reasons. Replaced 3-4 fasteners due to a missing jaw. Ordered a full replacement set through Amayama quite reasonably priced.
    * on a phone turn it landscape to see signature
    #8 Mendel Leisk, Aug 9, 2023
  9. Mike72903
    57
    Fort Smith, Ar
    Thanks all. Lots of good advice. I picked up a few from the dealership this morning. I was going to get more until I ask the price. I’ll order more, or a kit, from Amazon. I was disappointed the dealership which has been my only oil change place had left off the plastic panel to do the oil change. Also, for some reason the drain plug was not a metric size nut but 5/8 inch.
    #9 Mike72903, Aug 9, 2023
  10. Mendel Leisk
    42,352
    Sounds like a typical dealership: rushed mechanics don't have the time nor patience to deal with the underpanel.
    For the engine under panel fasteners here's my all-in price through Amayama, in November of 2019, for 11 of the regular and 2 of the larger (grey cap) ones, basically a full replacement set. Approximately $20 USD:
    Mike72903 likes this.
  11. rjparker
    11,116
    6,974
    Texas Hill Country
    Dealers are not using mechanics for oil changes in most cases. Around here they are separate even at the "maintenance advisor" level with separate driveways and waiting rooms from the service/repair guys.
    #11 rjparker, Aug 9, 2023
  12. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    I've been using the the Rexka branded ones from Amazon, and have found them to be pretty well built and true to the OEM designs. I did also get a kit that was not Toyota specific (mainly for the upholstery clips it also contained), but those look a lot more shoddily manufactured.
    Mike72903 and Mendel Leisk like this.
  13. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    They're a lot less expensive from Amazon, but Amazon descriptions often stupidly neglect to reveal the size hole they fit. I bought a box of the smaller (7-mm) size, and they seem just as good as the originals.
    When I bought my Prius used from the original dealer, which had also done all oil changes to that point, one of those fasteners was missing from the oil-change flap. They replaced it, no charge, when I complained.
    The oil drain plug has to have metric threads to fit the original threads in the oil pan. Perhaps you have a non-OE drain plug with proper metric threads, but a 16-mm head (vs. OE 14), which coincidentally fits a 5/8" wrench.
  14. Siward
    Siward Active Member
    314
    128
    Toronto
    I just bought 5 from the my dealership in Toronto, Ontario Canada. It costs $5 CAD each. Pretty expensive.
