What size is the exhaust tip?
Discussion in 'Gen 2 Prius Main Forum' started by oil_burner, Dec 3, 2017.
  1. oil_burner
    oil_burner Active Member
    249
    126
    I would like to buy an extension to the rear pipe since I have to park with the car idling for extended periods and the fumes are making their way back into the cabin. Has anyone tried this I'm thinking if extended a few inches further behind the car it would resolve my issues.
  2. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    Engine shouldn’t be idling for extended period. Unless it’s really cold and you have heater on high. Prius will only run the engine when it’s needed. So just first check that there is actually need for modifications. Sorry, no help for diameter but it should only take seconds to measure it with dial caliber or even a tape meansure.
  3. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    Ventilation air intake is under the windscreen and wipers. I doubt that a little longer exhaust would be much better. Except you aren't using the ventilation. Then the gases can enter the cabin through the ventilation air outtakes behind the bumper (at the side of the trunk). Instead of a longer exhaust pipe, I think, using the ventilation (for forcing the air direction) would be more effective, perhaps combined with an air filter made of active-coal.
    SM-G900F ?
  4. MickyMatter
    260
    168
    Germany
    However the outer diameter of mine is about 43 mm / 1,7".
    But it's not horizontal but diagonal downwards a little. And making is longer will reduce the space to the street. So better take a look first.
    SM-G900F ?
  5. oil_burner
    249
    126
    Yes it is freezing where I live which is why the heat needs to be on and the engine idles.
  6. Mendel Leisk
    42,376
    I guess if you crank the heat high enough the car's computers will force it to keep running most of the time? So I'd guess whats happening, is your sitting long enough the fumes from the exhaust are drifting around to the cabin air intake, at the bottom of the windshield? I can't see an exhaust tip extension helping with that.
    Personally I don't like any amount of engine idling while just sitting, either AC in summer, or heating in winter. Some places it's illegal to idle more than a minute, never seen it enforced though.
    What area in Canada?
