What size/offset for 16" wheels
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Andrax, May 25, 2013.
  1. Andrax
    Andrax Junior Member
    Hey all, sorry for the n00b question, but ive never been much for aftermarket wheels, usually buying gently used factory wheels that were a match already for a vehicle.
    Anyway, i thik i am going to get a set of 16" wheels and some Michelin Defenders from Costco during the current coupon. My 2010 isn't lowered or modified at all and is currently running oem 15" wheels which i will throw snow tires on this winter.
    Looking at TireRack for wheels, seems tgat there are a variety of offsets listed when i search for wheels based on make model. How do i know which is the best fit? Looking to maximize performance and fuel economy while cutting down on road noise.
    Thanks in advance for any assistance. Also, if there is a better place to get wheels let me know! ;-)
    SGH-T999 ? 2
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Are you sure Costco will install non OEM size wheels and tires? Mine won't due to potential liability.
    They wouldn't install tires on my previous vehicle even though I had gone to a plus one size that came from the manufacturer on a higher trim level. They clearly stated that they only install sizes that come from the factory.
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    You want a 16x6 or 16x7 with a +38 to +48 offset.
    The tire should 205/55/16.
    In that size I would recommend the Ecopia EP422 for best mpg, the PureContact for handling and wet traction, the Turanza Serenity Plus for an all around good tire. I don't think the Defender is the best choice in that size range but its not bad. Just make sure you get the lowest speed rating in any of the tires because the ones listed above have 2 speed ratings in each size. I.e. get the T rated tire if available, then the H then the V in that order.
  4. Anthro
    Anthro old member
    58
    Boulder, CO
    2021 Prius
    F8L, I'm still contemplating wider, lighter wheels (Enkei RPF1 15x7) for my C, for better handling, & Defenders in 15X195-60, also for better handling & also for ride & quiet (I now have the OEM Turanzas). Do your recommendations above still apply in this size range & purpose, and how much would Defenders lose in gas mileage?
    Thanks.
  5. EcoPersona
    EcoPersona Junior Member
    43
    22
    Orlando, Florida
    You should buy OEM 17" Wheels. My dealer is taking them off of my 2013 Persona next week when I install my new TRD Plus Package. PM me if you're interested!
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    For a 195/60/15 on your c I would go for the Bridgestone Turanza Serenity Plus over the Defender assuming you don't mind a mpg hit for better comfort and handling. The Defender may be slightly better than the Serenity Plus in terms of mpg but I bet they are close and the Serenity Plus is cheaper (assuming you get the $70 rebate on either brand) and tested very well with TireRack. Tire Test Results : Testing Grand Touring All-Season Tires
  7. Andrax
    Where are u at Eco?
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Check Discount Tire and TireRack for wheel and tire deals. They have a much larger selection than Costco.
  9. EcoPersona
    43
    22
    Orlando, Florida
    Central Florida. U?
  10. Andrax
    Idaho... Heh
    I'd love to take EM off ur hands, but the shipping alone would probably blow my budget from Florida.
  11. EcoPersona
    43
    22
    Orlando, Florida
    Sent you a PM. Maybe we can work something out.
    Anybody know the weight?
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Approx. 24lbs/ea.
  13. EcoPersona
    43
    22
    Orlando, Florida
    Thanks F8L!
  14. xliderider
    8,140
    3,280
    Honolulu, HI
    Wow, that's pretty tubby. :eek:
