What SPRINGS lower the Prius THE MOST?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by turnerdhr, Jun 14, 2009.
  1. turnerdhr
    turnerdhr HellaFlush(TM) Prius
    SINGAPORE
    Hey All....
    I just got a 2009 PRIUS imported to Singapore from Japan. It is the 1.5S with the 15" wheels. I will get 19"s put on her tomorrow. I am wondering which springs lower the Prius the most? I've read that some good threads here so far. I've also notice a 1" average drop in ride height. Does anyone know which springs lower the Prius the most?
    I'm looking for a real aggressive drop using springs only.
    THANK YOU!
  2. turnerdhr
    SINGAPORE
    and would anyone know the company that will ship the springs internationally to Singapore....?!
  3. Ken@kobetoba
    Ken@kobetoba New Member
    City Of industry
    PM sent, if didnt receive it [email protected]
  4. turnerdhr
    SINGAPORE
    Ken, this is my inspiration...
  5. drees
    drees Senior Member
    1,782
    247
    If you want to get your Prius that low, it is likely going to take some custom fabrication.
    Someone on here shortened the stock struts along with aftermarket springs to get their Prius that low. I don't know of any coilovers that would lower the Prius that far.
    Maybe bagging it is the way to go!
  6. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    I ordered coilovers for my prius and let you know how low it would go... I'm currently using trd sportivo springs/struts combo and I'm not satisfied with the drop it gives.....
  7. drees
    drees Senior Member
    1,782
    247
    I wasn't aware of any coilovers for the Prius - who makes them and where'd you get them?
  8. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    I got the Tanabe Sustec Pro NF..... other brands that are available are HKS, RSR, and GAB. I ordered them in Japan.....
  9. Blackbird
    Blackbird Huge member
    24
    SoCal
    That is basically asking for a bumpy ride.
    If your spring maintain the same spring rate as the stock ones and are simply shorter, you're going to hit the bump stops every 5 seconds = bumpy ride.
    If your springs are stiffer to keep your car off the bump stops than your dampers are too soft to work with the springs = bumpy ride.
    Springs and dampers rates need to be well matched in order to work together properly.
    Given that you're going to put 19's on it and basically eliminate the sidewall of the tires (meaning a serious reduction in the ability of the tires to absorb road imperfections), I suggest that you should at least consider upgrading the suspension in a proper fashion.
    Otherwise the result will be one seriously crappy riding car.
    Moti
  10. drees
    drees Senior Member
    1,782
    247
    For some reason I don't think the OP is worried about how it will ride - just how it looks!
  11. a_gray_prius
    2,927
    782
    IL
    More importantly, it will likely compromise the performance of the suspension system. I certainly support the OP's desire to lower the car but from my (racing) performance-oriented standpoint, it's not worth compromising cornering performance (which I suspect Blackbird is also concerned about). Whatever you do, please don't be a ricer and cut the springs (!).
    I do like the rubberband look on thsoe white rims. It's certainly distinct.
    bino, I'm really interested in know where you found the fitment guides for coilovers for the Prius? I'm interested in putting a set on my car although I am a little concerned about having to rebuild them.
  12. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    ygpm
  13. turnerdhr
    SINGAPORE
    Hey A gray prius,
    here are some pics of a white prius on scherzen tec coilovers. Vey very very nice indeed.... I've found out that there are a lot of examples of prius in Japan on coilovers running on 19s. I saw some very nice examples.... so that's what i am planning for with mine....
  14. a_gray_prius
    2,927
    782
    IL
    Wow, those are super thin tires. A little more negative camber and they'd look like they were running oni-kyan style. I can't say I like the rims as much - I'm partial to the gray gunmetal look.
    You're going for the whole VIP look?
  15. turnerdhr
    SINGAPORE
    ahhh..... well, maybe this is what you're talking about... note however, that she's running on 18s... but no less, she's on ADVAN Racing RZs...
  16. turnerdhr
    SINGAPORE
    and yes... i'm going for that minimalist slammed VIP Look on 19s... ... though still sourcing for a good set of coilovers at this moment...
  17. FuelSpender
    FuelSpender New Member
    22
    Tanabe DF springs just got released. Have you checked Tanabe Japan's Super Low form damper?
    They don't sell them in the states.
  18. turnerdhr
    SINGAPORE
    hey FUELSPENDER....
    you sure know your Tanabes.... yes, i just got to see THE LATEST Tanabe brochure (in japanese) on their SuperLow damper series for luxury cars... i saw crazy lexus, mercedes and other big cars rolling on at least 20s and they were like seriously maybe inches off the ground. I saw the spring rate numbers and i remember it being in double digits... so it made sense.. to be so low.... you have to ride real hard or you'll definitely be scrapping everything as you cruise along....
    too bad they don't make an application for the Prius NHW20 in that damper series...!
  19. FuelSpender
    22
    I just have a bit of experience in the car and aftermarket industry since i used to modify cars. I know more than JUST tanabes ;)
    But yeah, it's made for those kind of special customers who want the VIP Stype.
  20. a_gray_prius
    2,927
    782
    IL
    I'm a huge fan of Advan RS/RZs, so yeah that's exactly what I'm talking about.
