What the diff?
Discussion in 'Gen 3 Prius Technical Discussion' started by Jonny Zero, Feb 5, 2015.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    What kind of differential does the Prius have? Is it just a plain old open diff and relies on the FWD weight on the drive wheels and traction control?
  2. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Looks like a standard diff to me in the pictures.
  3. hlunde
    hlunde Member
    419
    75
    It's not limited slip if that's what you mean.
  4. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    I don't believe any front drive cars, including conventional gas engine, have a differential since transmission and differential functions are combined in a transaxle. Look at Wikipedia for a description of the Prius' Hybrid Synergy Drive.
  5. CR94
    CR94 Senior Member
    2,839
    1,245
    Northwestern S.C.
    In a word, yes. Traction control is supposed to minimize need for a limited-slip differential.
  6. alekska
    alekska Active Member
    435
    138
    Atl
    I assume you are trying to say - they don't have a differential as a separate unit. That's correct. Differential is inside of the transaxle.
    Alex
  7. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Yes, I was wondering if the Prius has an LSD to lay down all that awesome power! :confused:
  8. David Beale
    5,963
    1,990
    Edmonton Alberta
    Because of the aggressive traction control, limited slip would be superfluous. You can't really spin a/the wheels. Though if they added a Torsen type it might be better on ice and in the snow and mud, reducing the traction control intervention. ;)
