What the heck is this noise? Coolant pump? (video)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ericisbacchus, Apr 7, 2014.
  1. ericisbacchus
    ericisbacchus Junior Member
    91
    Kansas City
    Hey folks. What the heck is this noise? Coolant pump?
    I talked to Toyota, and it sounded like they would help me fix it. But, I have to take it to the dealer. I took it to a place (not the dealer) call ToyTechs. I trust them, and they said it was the inverter pump.
    Dealer said it was some other pump.
    You have to turn it up a bit. It's sort of a woot, woot, woot, etc. sound.
    What say you, my friends?
  2. Patrick Wong
    18,200
    6,472
  3. BubbaAllred
    BubbaAllred New Member
    Winfield, PA
    Was an answer for this ever discovered? My 2008 with 260k has the exact same noise as Ericisbacchus.
    Thanks,
    Billy
  4. JC91006
    16,479
    8,397
    This is the sound of a bad 3 way coolant valve. If you scan your car for codes, you should get p1121
  5. BubbaAllred
    Winfield, PA
    I checked the coolant level and it was low. I added about a quart. I'll see if the noise goes away. Thanks for the help!
    Billy
  6. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    Added coolant to thee engine or inverter loop?
    Was the engine loop recently serviced? Drain/fill or a part replaced? You may still have air that needs to get purged out. Many posts on getting air pockets removed. Do a search w/in PC or an Internet search.
