What tire pressures are you running?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by eric smith, Nov 18, 2012.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  2. lensovet
    2,615
    496
    Burlington, NJ
    lol. i suggest picking a 2010. or just consulting the manual, they should have what kind of fuse you need.
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  4. Frank Perkins
    Frank Perkins Member
    129
    66
    Fairfield, Connecticut
    Thanks, I looked there too. Ill stop by the dealer. I actually don't think I would have blew the fuse if I had the engine running. That's what I do on my Pilot with no issues.
  5. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Frank,
    What is the listed AMP draw of your compressor?
  6. Frank Perkins
    129
    66
  7. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
  8. eric smith
    eric smith Junior Member
    44
    DC/Maryland
    42/40 for me with the bridgestones too. Check your pressures often especially as the weather changes. I would even recommend going to nitrogen to eliminate large pressure changes for those who do not have a reliable source of compressed air at home.
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  10. Frank Perkins
    129
    66
    Stop showing off. :-P
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I love it when I'm right:D
  12. Frank Perkins
    129
    66
    Well.... I personally never said you were wrong, I just inadvertently proved your point. However, I'm going to buy a few extra fuses and try to use the compressor with the engine running. I think with the engine off it's easier to blow the fuse.
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Interesting tidbit in my inflator owners manual, it says do not leave engine running while inflating tires
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I think it won't matter if you have the engine running because 14.5 amps will blow a 10 amp fuse Frank
  15. Frank Perkins
    129
    66
    The accessory fuses are 15a though...
  16. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    you got documentation to back that statement?
  17. fuzzy1
    10,705
    Repeatedly running 14.5A on a 15A fuse is a recipe for short fuse life.
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    well, something did go wrong:eek: I was inflating the drivers side rear tire and the inflator stopped!!!!!:eek: The duck tape fell off the light sensor for the parking lights that are on the same circuit as my 120 volts outlet!!!!:eek: Turns out, the duck tape had been in the outside elements too long and lost it's stickeyness :LOL: found some fresh duck tape and inflator worked with out a hitch:D
  20. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Page 502 in the manual.. the CIG and the PWR OUTLET fuses are both 15A.
