What tires did you get on your 2010?
Discussion in 'Gen 3 Prius Main Forum' started by Danny, May 20, 2009.
  1. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    Interesting, this loaner has a build date of 02/10, same as my Prius...
  2. skibum
    skibum Junior Member
    33
    New England
    Yokohama's on a 2010 on a base black model bought in MA with the $750 rebate :) . So far 57 mpg's in 5 day's of driving, pretty amazing.
  3. Craigmri
    Craigmri New Member
    134
    We got the Goodyear Assurance on ours. Build date was 8/10.
    Craig
  4. rokibler
    rokibler Member
    88
    31
    Cabin John, Md.
    Prius III - Bridgestone Ecopia EP20, purchased Sept. 2010 in Maryland
  5. murigius
    murigius new but learning
    SF Bay Area
    Prius II (Berkeley, California) Yokohama Avid S33
  6. DavidJP
    DavidJP Junior Member
    Riverside, Southern California
    Prius II sold August 2010, Bridgestone ecopia EP20, southern California
  7. blake918
    blake918 Blizzard Brigade #23
    52
    Metairie, LA
    Bridgestone Ecopia EP20s on Prius II in South Louisiana (7/10 build).
  8. PhinneyJohn
    PhinneyJohn New Member
    Seattle
    Bridgestone Ecopia EP20, Prius III 9/10 build date, Seattle WA.
  9. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    Yokohama Avid S33. These are really quite low rolling resistance tires. The car rolls for ever and ever. My previous car was the 2006, with Michelin Hydroedges that had about 50 K miles on them. The 2010 Trim level III, with the Avids easily outrolls the old car below 40 mph. But, the warp stealth from 50 mph is much much worse. Might be the Aero mods I had on the 2006. On my warp stealth down-grade on the way to work the 2006 with aero mods would gain speed from 45 mph to 52. With the 2010, I have been starting at 47, and it barely stays above 45 mph at the bottom of the grade.
    Yes, I am working on flush hubcaps for the 2010 this afternoon!
  10. bnaccs
    bnaccs bnaccs
    191
    Colorado
    What is a better tire the Bridgestone Ecopias or the Yokohama Avids?
  11. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    The Bridgestone Ecopia is supposed to be a good summer tire with about a 30 percent rolling resistantc than some other Bridgestones. The Yokohama Avid gets good reviews for wet/winter, hydroplane management. As far as which one is best; looks like it depends on your application, preference and budget.
  12. gussomer
    gussomer New Member
    27
    Utah
    Ecopias for me.
  13. bnaccs
    bnaccs bnaccs
    191
    Colorado
    I live in Colorado and have the Ecopias on my 2010 that was produced 10/10. I love the dry grip of the tire and the low noise levels. I've yet to drive them in rain or snow. What makes a tire low rolling resistance? Is it the compunds that it is made of? Maybe I would be better off with the Avids, since they get a better snow rating. I know my Ecopias are taction B, or the Avids an A?
  14. twittel
    1,605
    148
    Mt. Pleasant, SC
    The lower rolling resistance comes from tread design. Same as a tire rated for hydroplaning where the tread channels push more water away from the tire at the road surface. To that extent, I think the Ecopia may have a narrower, shallower tread. This is not a bad thing, just a performance-driven design. The tire will still deliver excellent mileage longevity under normal driving conditions.
    Geez, I sound like a friggin commercial. Sorry, but I'm not recommending nor selling anything, let alone tires.:) I happen to run across this stuff when I shopped for tires a car ago.
  15. bnaccs
    bnaccs bnaccs
    191
    Colorado
    Are they also less polluting. If so how? Wow! You have a lot of tire knowledge.
  16. jdenenberg
    jdenenberg EE Professor
    3,929
    1,929
    Trumbull, CT
    2020 Prius
    LE AWD-e
    No, LRR comes from the rubber compound. You need to reduce energy lost when the rubber flexes. True LRR tires use Silicates in the rubber compound (replacing the carbon black) to achieve LRR.
    A secondary approach is to make the tire material thinner - not my favorite approach.
    JeffD
  17. Hokeysmoke
    Hokeysmoke Junior Member
    76
    Oregon
    Yokohama Avid S33 on mine
  18. handlebar
    handlebar Junior Member
    23
    South Florida
    Yokohama Avid S33 and I just filled them to 40psi
  19. twittel
    1,605
    148
    Mt. Pleasant, SC
    Thanks for the correction on the low resistance tire. Adding silicates does lower rolling resistance by making the surface harder. I guess I'm thinking of the variations in width, thickness, tread and pressure as contributing factors to LRR.
  20. CTpriusV
    CTpriusV Junior Member
    70
    Bristol Ct
    Michelin Pilot HX MXM4 on my 17" Package V 2010
