What tires did your Prime come with?
Discussion in 'Prime Main Forum (2017-2022)' started by Pizza Driver, Jan 9, 2017.
  1. bisco
    52,899
    michelin energy saver a/s. really quiet and smooth, good handling, may not have superior longevity though, i just got them.
  2. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    I had Yokohama Blue Earth on my 2012 Prius V and got 100k miles on them. Handled all conditions very well. I even overinflated them for better mileage. When my Dunlops need replacing, I will go back to the Blue Earth.
  3. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    Bridgestone Ecopia EP 422 Plus on my Prime Plus.
    Purchased in MD on Feb 2, 2017
    Vin 0048XX
    Does anyone know what tires are used by Toyota on the Prius Model 2 ECO?
    Does any one have rolling resistance data and tire weight data on the Prime and Prius ECO tires?
  4. Mendel Leisk
    42,377
    Would appreciate if you could you please post: country they were made (it should be embossed on sidewall), and a pic looking face on at the tread, if possible. Say at ground level, looking straight at either a front or rear tire.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Some reason to think they would be different than the ones on the web such as?:
    Bridgestone Ecopia EP422 Plus (H- or V-Speed Rated)
    No country of manufacture on mine, at least that I can find.
  6. Mendel Leisk
    42,377
    Going to your link, then the spec's tab, I see, using 195/65R15, two versions: one Mex, one US, with numerous differences, including number of rows of ribs. I believe there's also a Japanese version, with again a different tread configuration, UTQG, and LRR description.
    I'd suspect the Prius sport the Japanese version, likely the best of the lot. There should be a diminutive text on the sidewall stating "made in _____", you really need to eyeball it inch by inch, with a good light. And a pic of the tread pattern would be helpful, in my quest, lol.
  7. Lee Jay
    5,850
    4,036
    Well, I bought mine at Firestone, they are 185/65/R15, treadwear 640, and they look like this:
  8. Prodigyplace
    12,720
    11,852
    Central Virginia
    The Eco uses the same tires as the Liftback with a higher recommended tire inflation. Various tires are used. There was a thread last year in Gen 4.
    My Prius has the Japanese Ecopia 442 Plus.The Ecopias are made in 3 countries with differing ratings & tread design.
    Gen 3 for me and Mendel Leisk like this.
  9. Mendel Leisk
    42,377
    Thanks. Those look like the US version. The Japanese appear to have wider intermediate tracks, less of a gap in between. And some difference in the tread pattern. This is supposedly Japanese 195/65R15, with wear index 600:
    More info here:
    Feedback of Ecopia EP422 plus? | Page 8 | PriusChat
  10. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    Made in Japan K1502 EP4AYZ DOT EL 9N (DEA4641) (in brackets is changeable mold insert. I know 4616 means 46th week of 2016), Treadwear 600, Traction A, Temperature A.
  11. Mendel Leisk
    42,377
  12. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    I believe the version on the Prime from looking at my tires are specific to the Prime. The link above is for 91H load and speed ratings which should be a more generic tire to fit various vehicles with more weight. My Prime's tires have load and speed ratings of 89S. Max Load 580Kg 1279 lbs. Plies thread: 1 polyester + 2 steel + 1 polyester. Sidewall: 1 polyester.
    In my former job in automotive I learned that tire manufacturers fine tuned tires for each model of car to the OEM Car company handling engineers requirements. But the actual car owner could not generally get the same tire when replacement was needed. The tire manufacturer responded to my questioning as the car owner could not tell the difference. I agree since once the tires get worn the handling characteristics, noise etc change for the worst. Putting on a new tire of similar but not exact construction will please most consumers.
  13. Mendel Leisk
    42,377
    One thing I think would irk most consumers is obvious tread pattern variation. It would certainly bug me.
  14. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    The tire manufacturer is not likely to expect consumers to accept an obvious thread pattern variation.
    It is what you can't see on the inside: construction and compounding that is different.
    However, if we observe what is posted in this thread and the link to the Gen 4 discussion we see differences:
    89S vs 91H clearly understandable on the sidewall
    Tire construction code: EP4AYZ for the Prime from Japan vs the EP42EZ from USA and EP4WAZ from Mexico being different for the tires sold at Tire Rack which are not Prius specific.
    I wish I could find rolling resistance data, along with actual tire weight, to go along with the good data that is posted on tire rack to help in making the decision when replacing my car's tires. I don't think I will face this challenge for my Prime for at least a few more years.
    #34 Gen 3 for me, Mar 19, 2017
  15. Prodigyplace
    12,720
    11,852
    Central Virginia
    If those are 15 inch they are probably what is on my Prius Liftback.
  16. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    Yes 15 inch
  17. Mendel Leisk
    42,377
    Quite a difference:
  18. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    I must say, I'm not a fan of those wide grooves on the US version (less rubber on the road). That said, I put a set on my 2013 liftback the other day. Took advantage of the Costco $70 off sale. The ride is smoother and quieter than my worn EP20s, but I guess that is to be expected.
  19. Mendel Leisk
    42,377
    I emailed Bridgestone a few days back, asking about these differences. Nothing back yet. To be fair it could still be plinkoing around their beurocracy. I'll post if they respond.
  20. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    1. Any experiences of using Stock tyres in snow? I am wondering whether to put Michelin Cross Climates on my coming new Plugin/(Prime), because I like the ones I have on my Gen2 so much. (Am assuming I could sell the stock tyres almost new on eBay and get a fair amount of the value back to help pay for the Michelins.)
    2. Re aging and noise, in the UK new tyres now have to have a decibel rating for noise and other ratings such as rolling resistance. Are you saying simply that tyres get gradually worse as they age relative to their starting point, or that as they age, they all become as bad as one another?
