What tires should I get for my 2012 C?
Discussion in 'Prius c Main Forum' started by Josh331, May 8, 2019.
  1. Josh331
    Josh331 Junior Member
    47
    Coeur d'Alene ID
    It came with 165 65 15 but a buddy told me he thought I would actually get better mpg with 175 65 15 so I have been running those the last few years. Getting my snow tires off so what would be the better tire for MPG but also handling?
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Mine came with 175/65/15, interesting that yours didn't.
  3. Josh331
    47
    Coeur d'Alene ID
    Yep, 165s is what it came with
  4. Energy Savers A/S 175/65/R15
    ztanos likes this.
  5. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Were they original? My understanding was the OG tires were 195 or 175.
  6. Josh331
    47
    Coeur d'Alene ID
    Yes they were 165s
    ztanos likes this.
  7. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    But were they the original tires? Or were they the second set of tires that you bought the car from someone and that's what they had on them? Just curious.
    Lukey51 likes this.
  8. Josh331
    47
    Coeur d'Alene ID
    I drove off the lot with those tires on them, brand new. So does anyone know what would be a better tire, if it even matters at all? I want it to handle well obviously but have the best mileage,
    165 vs 175
  9. Mendel Leisk
    42,354
    From Owner's Manual, the stock 15" tire size:
    Maybe Michelin Energy Saver A/S?
    #9 Mendel Leisk, May 10, 2019
  10. hackenfort
    hackenfort Member
    62
    40
    2016 Prius c
    Mine current C came with 175/65/15 I just replaced them with 185/60/15 (same as the Yaris),
    I found a greater selection of tires, and I didn't take a hit on MPG and IMO seems like it rides better, I know it's much quieter due to the new rubber.
  11. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I'd go with any 15" tire 175 or 195 as those were both the factory sizes from the 2012 car... at least that I had seen before yours. Just make sure they are eco LRR tires.
  12. Royston.K
    Royston.K Member
    75
    60
    Singapore
    For factory 15x5.5 I used Michelin Pilot Sport 3. Best tyre available for this size is 195/60/15 and still able to fit the factory wheel.
    I'm since moved to 16x7 and using 205/50/16 Michelin Pilot Sport 4 which brings it to another level. Good wet & dry grip and decent comfort and noise.
    Personally I don't use eco & comfort tier tyres. Over here in Singapore we got rain pretty often so we can't go for dry tyres like RE71R.
  13. frenzee
    frenzee Member
    95
    73
    16
    Costa Mesa, CA
    Does anyone make tires with white lettering (not the stick-on type) that would fit the OEM wheel size?
  14. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    You could use a tire pen to make your letters white. I've seen a few of these that look really good.
  15. frenzee
    frenzee Member
    95
    73
    16
    Costa Mesa, CA
    Thanks ztanos. Have you see them in person? Pictures can sometimes be rosier that that the real thing.
  16. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I have seen one on a mustang with goodyear tires. They looked slick.
  17. Josh331
    47
    Coeur d'Alene ID
    I remember when I had the 165s on it was very quiet on the road compared to my studless 175 snow tires. If i purchase some larger tires like some have you suggested (190 65 15 etc) how will those effect the noise, MPG, handling etc
  18. Leadfoot J. McCoalroller
    8,290
    7,806
    Pennsylvania
    2018 Prius c
    Snow tires are usually a bit loud due to the aggressive tread pattern, and once they have age-hardened a few years forget about it, they'll be very loud. So it's not really fair to compare an all-season tire to a snow tire for most criteria.
    Size won't make much difference for noise. Mostly it's the elastic quality of the rubber compound and the specific shape and angles of the tread pattern.
    I had Michelin Pilot Sport A/S3 on another car and loved them, very quiet. I had no idea they were offered in sizes small enough for a Prius, that's great to know! Thanks @Royston.K
    I like the General Altimax RT43 on our other subcompact. They don't cost much, give excellent traction performance and they're very quiet. They aren't green/eco/LRR rated but they still give good MPG. I was planning to put a set on our c once we wear out the factory Goodyears, but now I have to consider a set of Pilot Sports...
    ztanos likes this.
  19. Mendel Leisk
    42,354
    I'd second that.
    Stick with the size spec'd in Owner's Manual (for a number of reasons), and consider various tire makes and models.
