What to do about transmission fluid
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Angry Elf, Jan 8, 2013.
  1. Angry Elf
    Angry Elf Junior Member
    35
    I called my dealer to get my oil changed in a few days . When I asked about the transmission fluid change he said it would cost $180 . He asked how much mileage was on my car I told him 24,000 miles , He all but refused to do it . He said it was far too early , they don't recommend it before 60,000 miles . Now what ? I've read on here some people believe it's very important to do it about 30,000 miles . I would do it myself , I can buy low-profile car ramps But then how do you get the back wheels up to make it level? Does anyone have advice on where to lift the car with a forecheck ? Or how do you get your car up to change transmission fluid ? I've done considerable automotive work before but this is a little different than old pick up truck .
  2. Angry Elf
    35
    * Floor jack *
  3. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My dealer in CT charges me $100 for the drain/refill but would probably have balked at doing the first one at 30k miles until I showed him the lab data (attached here). Note the high metallic load at 61k miles and the lower numbers at 120k and at 180k. Make sure that he is not quoting the cost for an ATF "flush" (costs more than a simple drain/refill) as that is not required for a Prius.
    JeffD
    F8L likes this.
  4. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Jack one side up with any jack (the one for changing the spare tire will do). Then place a jack stand under that side and let the car down on it. Repeat for other side. Don't get under the car without a fixed support. I've got some ramps purchased for use with an older car, but the Prius doesn't have the clearance to drive up them. But they work fine to hold the car up after jacking it.
    $180 for a procedure as complicated as an ordinary oil change is rather steep. As a DIY project, just be sure to use the Toyota specified oil, remove the fill plug first, and know how you're going to get the oil in the fill hole before you drain the old oil...
  5. Angry Elf
    35
    It was my understanding that the car had to be level to get the proper fill level on the transmission , meaning all 4 wheels would have to be in the air at the same time . I have four jackstands and a low-profile floor jack , I successfully Put the front end up to put in my engine block heater last week But wasn't sure if there was a safe way to get all four tires off the ground . If the transmission service can be done with just raising the front tires that's extremely simple .
  6. RobH
    RobH Senior Member
    2,385
    991
    70
    It's been a while since I changed the transmission oil on my Gen2. What I did was to back the car into my slightly sloped driveway, and jack up the front end. The drain hole looked low enough to get most of the oil out. I refilled from the top with a funnel and a long tube. It took the expected amount of oil, and probing the fill hole showed the level right up to the hole. The car was maybe 3 or 4" higher at the front than back, and the tilt didn't seem to upset anything.
    The wrenches required to remove the drain/fill plugs are unusual. I think one is a square drive, and the other some sort of allen. Finding a funnel with a long enough tube was another project. These are all non-issues for a mechanic who regularly performs the service, but as a DIY type, I had to go purchase the sockets and funnel required for the project. It would be useful to have another car available to go on a shopping trip while the Prius is up on jack stands...
    Angry Elf likes this.
  7. Mendel Leisk
    42,117
    I raise the front end with a regular (not low profile) floor jack, set it on safety stands, then raise the rear with the floor jack and again set it on safety stands. Before setting the rears down I put a level on the rocker panel and try to get it to settle down close to level.
    The rear safety stands I put on the rocker panel support points, as outlined in the Manual. But for the front ones I put them a little inboard, at the front of a rail that runs front to back.
    Then, before getting under, I push a section of tree stump under there to keep me company. It's a bit thicker than me, makes me feel secure. ;)
  8. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I called my local dealer, first they quoted me $300.00.
    When then found out I only have 36K, they refused to do the change!
    Gotta make some more phone calls!
  9. Mendel Leisk
    42,117
    Yes, I'd phone around, between the price and digging in their heels like that, there's got to be better.
    The fluid and washers should come in under $40. The labour, realistically: 1 hour. I mean, second time around, I could practically do it in an hour. For the dealership with a hoist...
    My sense of when to do it: first change should be quite early, and then spread out the following changes. I did a change (myself) at end of year one, and intend to do bi-yearly changes from here on.
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Your dealer is confusing the fluid change method of the Tacoma and the Prius. The Tacoma requires a thermal fluid flush which is MUCH more involved. The Prius is just a drain and fill. The dealer charges 1/2hr labor and about $40 for the fluid and washer. Have them call Magnussen Toyota in Auburn, CA to verify if they can't figure it out. They were the only ones in my area who knew what the hell they were talking about. Everyone else wanted $280+.
  11. KK6PD
    4,003
    946
    118
    BINGO, Justin, you nailed that right on the head.
    The guy got into telling me about getting the oil to temp, hook up computer, blah, blah, blah. I kept insisting it was a simple drain and fill, he just would not listen!
    Next call I make, if the new service tech tries that bit, I can remind him, Prius, not Tacoma!
    +1 Pal!
    F8L likes this.
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Good luck, brother!
    I'll get the name of the service guy at Magnussen's for you so you can reference them if needed.
    KK6PD likes this.
  13. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    If he can read, tell him to read the Toyota Prius factory repair manual. The instructions are basically the same as a manual transmission oil change except is uses WS.
  14. Angry Elf
    35
    Ok i have read all the post and I thank I got everything to do this job , oil , funnel , hose , tools , extra plastic pushpin retainers , ( just in case ) . All about $52 :) . We'll see how it goes this weekend .
  15. KK6PD
    4,003
    946
    118
    Depending on how this works out for you, I may follow your lead. Please take a couple of pics, I would love to see your results!
  16. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Here are the Gen III transmission oil change instructions from the Mothership's repair manual
  17. Rivetjoint
    Rivetjoint Junior Member
    New Jersey
    My local dealer here in NJ didn't give me any problems when I requested they change my ATF at 73,000 miles. I was ready for a battle but they quoted $89 so I took them up on their offer. BTW, you folks in Northern California could always avail yourselves of Luscious Garage in San Francisco. I have no skin in their game but if I lived out that way they seem to have excellent references and reviews of their business practices. Luscious Garage | Hybrid Specialists
  18. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Here are a couple of my UOAs from the transaxle of my 2010 Prius. I'll send in another sample when I change it again at 80K to see if there is still a high aluminum content.
    Here is an old thread that may be of interest, post #35 contains a procedure for transaxle fluid changes that works pretty good. DIY Transmission Fluid Change? | Page 2 | PriusChat
    KK6PD likes this.
