What to do by 100k-120k miles?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by StephenJ, Aug 27, 2017.
  1. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Hey guys, I just picked up a 2009 Touring. I'm not exactly sure what all has/hasn't been done so I want to do some maintenance on it before we put it to work. It has 109k miles. Aside from oil changes what all should have already been replaced by now (or soon like120k miles)?
    How many miles does a 2nd Gen get out of the waterpump, 02 sensor, coolant for engine and hv battery, other stuff that I'm way too tired to think of
    Thanks! Can't wait!
    Stephen
    #1 StephenJ, Aug 27, 2017
  2. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    I'm planning on draining/refilling coolant, checking the brakes, checking trans fluid. I don't know much about the hv battery/inverter system except it has its own coolant....does it get changed on same schedule as engine coolant?
    I'm curious about spark plugs, water pump, thermostate, belt, tensioner pully....anything else that is common to go bad.on most cars around 100k.
    Also...on the Toyota site it had "basic tuneup" does anyone know what is included in that? That's all it says
    Thanks!
    Stephen
  3. Moving Right Along
    Moving Right Along Senior Member
    739
    596
    On the Toyota owners site, you should be able to see more details of any given item, as long as the dealership provided them.
    On my car, when I got it at 105,000 miles, the only additional items done aside from regular maintenance schedule were: 12v battery replaced at 60,000 miles, drive belt replaced at 96,000 miles, tires replaced at 90,000 miles, steering wheel centered at 105,000 miles, and 3 recall repairs. Spark plugs are due at 120,000 miles along with a bunch of other things.
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  5. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,850
    Hyampom
    Do what the manual says needs doing by 120K and hope the previous owner(s) did the required maintenance.
    Really only thing might be the inverter coolant.
    If you want to be cautious, could do a drain and fill on the transaxle.
    My water pump went out a few years ago (60-K-ish), but other than that, the oil changes, the transaxle drain and fill, the inverter service and a new 12-volt battery, pretty much trouble free.
    Opps, forgot, cleaned the MAF around 70-K and the throttle body. Also had to replace the rear hatch lock switch about a year ago (a common problem). Oh, the side view mirror, which I managed to break off when I hit a doe last December.
    Finally three or so engine air filters and maybe 20 cabin air filters (I had mice problems).
  6. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Thanks! That's pretty much what I had in mind! Replace engine coolant, transaxle oil, inspect brakes, I may change spark plugs plugs.
    Is the "inverter service" just a drain/fill of the fluid? You guys just use the same coolant as the engine uses?
    While replacing the engine coolant I may see how much it would be to replace the water pump since it sounds like it doesnt last too long. At 109k I don't have any record of it being replaced.
    Based on the thread about transaxle oil analysis it looks like everyone just uses the Toyota suggested oil.
    Are there any suggestions for spark plugs that really do make a difference in gas mileage or does everyone just stick with the OEM plugs?
  7. cyberpriusII
    1,157
    1,850
    Hyampom
    Use the Toyota suggested fluid for the transaxle because that is the only fluid that is approved by Toyota.
    Sure, experiment if you want. Personally, I am not an automotive engineer. I will pay the price Toyota wants for the stuff.
    Same with the coolant. Use the Pink stuff that Toyota approves of. Both for the inverter and the radiator.
    Some people have good experience with the Prius Water Pumps, some, such as myself, do not.
    Personally, I would NOT replace it if it does not need replacing. It is a big pain. I paid to have it done at the dealership....-- $450.
    Spark plugs. I really don't recall seeing anyone claim any particular plug gets better MPG> Denso SK16R11 or NGK IFR5-A11 both would work.
    Just for the heck of it, since you don't seem to know much about this car, and both Luscious Garage and I recommend it, I would pull the hybrid battery cooling fan system apart and make sure it is clean and tidy. Prius battery cooling fan cleaning, P0A82 - Luscious Garage | Hybrid Specialists
    That could make a big difference on life of the battery. A bit of a PIA, but worth it if that fan is clogged/gunked up.
    #7 cyberpriusII, Aug 27, 2017
    SFO likes this.
  8. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Thanks so much! The fan is a great suggestion. I appreciate that!
  9. DevChatt
    DevChatt Junior Member
    92
    31
    Bethlehem Pennsylvania
    Here is what i recently did at 104k
    Dealer:
    -Transmisssion drain and fill
    -Waterpump/ fix a broken trans seal--had a coolant flush with it.
    Myself - very easy to do all by yourself:
    -Spark Plugs
    -PCV Valve
    -Air Filter
    -STP in fuel injector (probs not really necessary, but I have long periods of not driving due to work so it doesnt hurt)
    -Clean Throttle Body
    -Clean MAF
    To Do:
    Drivebelt---maybe? IDK if it is necessary...don't feel it, may not need it.
    Inverter coolant
