What to do with spare engine?!
Discussion in 'Gen 3 Prius Technical Discussion' started by Aaron Vitolins, Apr 19, 2018.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    What’s parts did you get:whistle:?
    I see the oil filter housing above, but something else:)?
    Spare egr setup maybe(y).
  2. mjoo
    mjoo Senior Member
    1,162
    1,331
    Michigan
    Good guess. I got the oil filter bracket and canister, OPS and oil pan. I have some bypass filter stuff in storage that I'll eventually put on.
    When it arrived I was shocked at how shallow that oil pan is. I'd be surprised if it held much more than a quart of oil. Any engine with a leaking oil pan gasket will dump it's sump in a hurry.
    Pixel XL ?
    Aaron Vitolins likes this.
  3. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    So glad! Very welcome
  4. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Hey I checked out the water pump, it turns by hand, it doesn't spin freely. It actually seemed kinda bined up or something. Bearing worn out or something. Not good!
    Raytheeagle likes this.
  5. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Thanks for circling back;).
    No bearings as it is a magnet driven pump:).
    Good data point (y).
  6. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Hmm, so it's supposed to spin freely? Any theory's here?
  7. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Might just be some impeller distortion over 9 years, not sure ;).
    Trying to get as much info from in service pumps to see commonality :).
    Since the coolant is not getting through the liner and onto the bearings, it’s not magnet failure ;).
    Thanks for the data(y).
  8. Rob808
    Rob808 New Member
    Corbin KY
    What do you have left on the engine? I'm interest in the head and block.
  9. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Almost everything!
  10. Rob808
    Rob808 New Member
    Corbin KY
    I live in Ky how much would you take for what you have left? I could come get it.
  11. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    The everything but the oil pan, oil pressure sensor, oil pan, oil filter housing, and egr cooler. Water pump is taken off but you can have that. I'd take $70.
    mjoo likes this.
  12. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    See post above^
