What to expect if I run down my 12 Volt battery
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by johnhlong, Sep 5, 2013.
  1. johnhlong
    johnhlong Junior Member
    89
    29
    East Carbon, Utah, USA
    I have the 2013 Prius C2.
    From time to time I will be running accessories off the 12 volt battery while stopped or parked.
    What troubles am I looking at if I manage to run down the 12 volt battery?
    Can I just leave the car in "Ready" and will it start the car as needed to keep the battery charged. Or will it just run the 12 volt battery down?
    I've been known to go camping and do this for 8-12 hours at a time.
    John
  2. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    Leave it in ready and make sure you have plenty of gas.
    It will occasionally start and stop as needed.
    Or bring a portable battery charger or spare battery.
  3. johnhlong
    89
    29
    So it will automatically start and stop the gas engine to keep the 12 volt battery fully charged?
    I couldn't ask for anything better. :whistle:
    That and some spare gas just in case........
    Any other drain on the 12 volt battery when the car is in "Ready" ?
    John
    TheyCmeNow and ztanos like this.
  4. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    When the car is in Ready, the DC-DC Converter handles all the electrical loads on the 12V bus It drops the HV Battery nominal voltage of DC 144 V to approximately DC 14 V. Since 14 V is higher than the Aux. Battery, it is charging the Aux. Battery.
    When the HV Battery SOC gets below 40%, the Power Management ECU will command ECM to start the engine so that MG1 can charge the HV Battery. Once the SOC reaches above 45%, the Power Management ECU will command ECM to stop the engine. The cycle repeats once the SOC drops below 40% again.
    If you do not want to risk running down your Aux. Battery, try to avoid using ACC mode or Ign-On mode, use only Ready mode.
    Vincent
    valuequest and Andyprius1 like this.
  5. johnhlong
    89
    29
    Slick. That will work great for my needs.
    Basically a big, expensive, mobile 12 volt generator :sneaky:
    When in Ready only mode is 12 volts available at the cigarette lighter socket or do I need to connect directly to the 12 volt battery?
    What does SOC stand for?
    John
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I will add that you do NOT want to be in N, you want P. You can't recharge the HV Battery in N. (Toyota is legally required to have an N, but you want to avoid ever using it)
    Yes, the cigarette lighter (Power point) is powered in Ready.
    State of Charge is how 'full' the HV Battery is.
    steveoknievo likes this.
  7. johnhlong
    89
    29
    Everything I ever wanted! AND it only cost me $20,000.
    TheyCmeNow, Rob.au and Andyprius1 like this.
  8. bisco
    52,883
  9. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    . That is definitely one of the sweeter points about the C, makes me tend to wonder IF I should have bought the PIP last year! But, no regrets, the PIP will be my 110V EV and the C will be my excursion car. I have only had the C for about 30 miles and am absolutely amazed at the mpg. It seems far more efficient than the other straight Toyota Hybrids. WHY ? , lighter? Better technology, what.??? I am busy returning to my hypermiling techniques.
  10. Andyprius1
    2,327
    859
    Cool CA
    Incidentally, as far as I can see, the C is not only the least expensive. But seems to be the best in MPG also.
  11. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    The c's strength is in city driving, most likely due to its lower weight. Out on the freeway, the liftback's better aerodynamics for lower drag give it the advantage.
  12. Andyprius1
    2,327
    859
    Cool CA
    Very true, but I see a lot of posters commuting 40-80 miles at 75 mph, so I guess the C can take it........?
  13. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Yes, if you already own a c, freeway commutes are fine. If you are looking, other Prius do better on freeways.
  14. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    Take it? Cruising at 75 down a freeway is nothing for a c. The liftback will beat it on fuel economy due to the reduced drag, but there's no issue with capability.
    Andyprius1 and ftl like this.
  15. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    Though unless you find a better deal on the liftback than on the c and/or if you drive 90% on the highway, the ~$5,000 more you'll pay for a ~2-4 mpg gain (from ~46 to ~49 mpg) in the liftback won't pay for itself.
  16. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Correct. If my job fit in a c, it would only cost $140 more a year for me than a Liftback (my job just barely fit in a liftback, but is much easier in a v)
    minkus likes this.
