What to look for when buying a used Prius w/Solar Roof?
Discussion in 'Gen 3 Prius Main Forum' started by nanoxnano, Feb 20, 2015.
  1. Boji
    Boji Junior Member
    59
    Ottawa, Canada
    Waaaaiit a minute... are you saying that the A/C button on the fob can be used as a remote starter to heat the car up in the winter? I ask because I'm shopping for a Prius now and that'd be a really nice feature...
    Edit: Sorry about that, just reread your post and figured out that you bought a third-party remote starter.
  2. Tideland Prius
    16,559
    @Boji , yeah the Remote A/C is only for cooling in the summer. The A/C compressor is electric and runs off the high voltage battery so it the engine doesn't run when you engage Remote A/C. A remote starter.. well you know how a remote starter works.
  3. qdllc
    qdllc Senior Member
    1,377
    400
    I'm not sure about 3rd party, but Toyota has a remote starter option. Nothing fancy, it's probably a control module that reacts to a sequence from the FOB that comes with your car. Two quick clicks of LOCK then press LOCK and hold until the car beeps and flashes its lights. It'll start up and remain locked for 12 minutes. Have your AC pre-set for temp and/or vent options and you can have it cool/heat year-round. The gas cost is negligible.
    If I lived in Florida, or someplace hot most all-year, the solar option with remote AC might have done the job, but it gets COLD here with snow/ice. That pre-warm up was worth the cost. Note that the factory says it's a $500 option, but your dealer will charge what it costs them to get it. Be sure to wrangle on the price up-front. No Prius should come with remote start standard from the factory, so I don't know why the dealer pays a higher price to get it pre-sale to a customer.
    Boji likes this.
  4. Boji
    Boji Junior Member
    59
    Ottawa, Canada
    Wow, thanks! I had no idea of this. I'll have to give it a try when I go test drive it again.
  5. qdllc
    qdllc Senior Member
    1,377
    400
    Good luck finding a Prius with one factory-installed. It's not part of any trim package.
  6. Boji
    Boji Junior Member
    59
    Ottawa, Canada
    Oh sorry, I thought it was a hidden function of the Prius remote. Thanks for clearing it up.
  7. qdllc
    qdllc Senior Member
    1,377
    400
    No. It just doesn't need a special remote to work. It uses the standard FOB once installed.
    Boji likes this.
  8. ramattos
    ramattos Junior Member
    57
    Bethlehem PA
    ive actually had my fan run when it was in the 20's and the cabin over 80 from an external heater
    i find the remote ac unneeded since the remote range is so short
    Boji likes this.
  9. Wandering Elf
    Wandering Elf Junior Member
    28
    Perth, Western Australia
    Here is an example of solar panel discoloration/corrosion on a 2009-2011 Prius. It looks like moisture
    has come in from the front of panel. I don't know if its still working, will soon fail, or has already failed:
  10. Vivi
    Vivi Junior Member
    I live in Chicago too and love the solar roof and the sunroof. Love having the light inside the car and having the sunroof open on a summer night.
  11. maurices
    maurices Member
    128
    37
    Sartell, Minnesota
    I live in Minnesota and agree with what Vivi stated. I had it in my 2010 and my 2013
  12. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    You can extend the range of the fob and thus stay the a/c from further away by putting the fob partially on your mouth even using it from afar.
    The skull acts as a resistor and sends the signal further.
    Agreed, the remote A/C makes modest difference.
    I figure - just do it. It helps a little bit, and takes a second to do.
    But I think it cuts off when you open the door? (it's been a while...). Then you have to turn on the car anyway to get the a/c going. IIRC. Yeah, a little lame..
