What type of bulbs are these?
Discussion in 'Gen 3 Prius Main Forum' started by Friendlyx, May 12, 2019.
  1. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    The bulbs keep twitching back and forth, and I'm guessing they are bad? I'm looking to see if you guys can tell me which bulbs these are? I've circled it on the picture 2015-toyota-prius-hybrid-three-hatchback-headlight.png.jpeg
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    You can get sylvania 2825 bulbs for that light ;).
    A 2 pack costs around $10:).
    Good luck (y).
  3. ChapmanF
    19,037
  4. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    I looked them up, they look like regular bulbs? The one my Prius has it's like an led one? Like the "new " looking bulbs
  5. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Any markings on the bulb or anything in the owners manual?
  6. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    161, 168, 194, 2825. Many different numbers look the same, the wattage draw(and perceived brightness) is where the difference lies. I put Sylvania 168 LED bulbs in mine. We had a changeover from single bulb in a pack of LED to two per pack at my work. The single bulb packages needed to be “disposed of”, so I did that. LoL
  7. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    Hmm, I just took it out and I can't see any numbers or anything on it. He's a picture, I don't have the Manuel because I'm not the original owner and it didn't come with it :( I looked up the Sylvania 168 LED mentioned and those look more similar, but still not the same. Are they just knock offs? Thanks in advanced! IMG_3135.JPG IMG_3754.JPG
  8. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Those are cheap knockoffs. 100 of them for 3 dollars on wish.com
    Montgomery likes this.
  9. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    Confusing because the previous owner evidently replaced the original bulbs with these "twitchng" LEDs.
  10. ChapmanF
    19,037
    Somebody put in an aftermarket LED from one of those packages that say "for off-road use only". The original is the 5 watt wedge base linked in #3. They last about forever (I've only just lately replaced two in my 2010), so if the LED one only lasted this long, that's kinda sad.
    There are lots of similar-looking bulbs but, as cnc points out, they're hard to tell apart by looking for marks and they're not all 5 watts (many common ones are less, for use in instrument panels and such). Since Toyota's price is reasonable, just giving them that part number is an easy way to get the right thing.
  11. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    Thank you! After you guys posting the new ones, I started to think these are knockoffs, but now I know! Thank you guys, problem solved! I'll be buying some OEM now!
    Raytheeagle likes this.
  12. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    They aren't even proper knock-offs, but just low-grade LEDs. Standard bulbs of the proper designation (size, base, and brightness) from a non-dealer source should be fine.
  13. ChapmanF
    19,037
    On the other hand, the non-dealer 2 pack for $10 suggested in #2 is a higher price than the dealer list price (which, in turn, is often higher than a dealer's discounted price).
    I'm sure you can find a good deal comparison shopping (and making sure to check the wattage) ... but if you value your time at, say, minimum wage, then even five minutes spent comparison shopping will eat up a lot of the possible savings.
  14. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Bought those before in a Prius led swap kit, utter crap. Either twitched or died and brown out within months. There’s just no proper heat dissipation foundation. Id just go back halogen side markers in your shoes.
  15. pokenoprius
    pokenoprius Member
    51
    27
    New Zealand
    2018 Nissan LEAF
    Please excuse my ignorance , are those the side indicators? Im guessing they are, as the international models also don’t have the wing mirror indicators.
  16. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Are there OEM Toyota LED replacements? I haven't heard of that.
    I've also bought some of these W5W LEDs off of aliexpress for my numberplatelight. One developed an intermittent dropout and I didn't like the cold white look of them so I've stuck the orignals back in again.
  17. ChapmanF
    19,037
    To what advantage? The OEM incandescents are cheap, seem to outlast these LEDs, and have the specified light output pattern so their packages don't have to say "for off-road use only", and they're all of 5 watts to start with, so how much would you be hoping to save relative to the overall power budget of the car?
    Maarten28 likes this.
  18. Maarten28
    415
    224
    Netherlands
    Exactly my idea. Some seem to be off the opinion that the colder white light of LEDs looks good. I don't. And as you say, the power difference is low and when they are crap it does not seem to be worthwhile.
  19. ChapmanF
    19,037
    "colder white light" = "with stronger blue components". And then put it behind an amber lens that works by taking the blue out?
    CR94 likes this.
  20. Maarten28
    415
    224
    Netherlands
    :D I used mine for the licenseplate lights. No amber lenses there.
