What will Fail in a Prius 2005 63K Miles ?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wirelessjava, Aug 19, 2016.
  1. wirelessjava
    wirelessjava Member
    103
    Union City, CA
    Hey
    I have had this Prius for a long time and I wanted to know what will fail next
    Currently at 55K miles the Hybrid battery was replace free of charge from Toyota
    The next major item was error code p1120 - Coolant control valve replacement which was done free by toyota
    WHAT is the next major item I should check on my prius 2005. Now I am driving it everyday
    ---wire
  2. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    Inverter coolant pump, 12v battery, check water pump, and serpentine belt. Change trans fluid and plugs @100k.
    I'm sure others will chime in with more.
    fotomoto likes this.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Given the complexity of any modern automobile I think trying to predict what will fail next an impossible task.
    If your question is, what recommended maintenance would anyone suggest at 11 years old and 60,000 miles. That's a different question.
    That's amazingly low miles for a vehicle that age.
    But I see by your signature that you own two other vehicles including a newer Prius.
    Since this is one of 3 vehicles, I'd just do a 60,000 mile recommended maintenance.
    Then if anything fails....decide whether to fix it or sell it, as you drive one of your other vehicles.
    The problems is the gap between actual miles and actual years. But a good tech or mechanic could probably let you know what areas should be addressed.
    eye144 likes this.
    49,726
    hv battery is really the only major item that suffers from high years and low miles. you should be fine.
  5. Kenny94945
    Kenny94945 Active Member
    788
    401
    Sausalito
    2016 Prius v wagon
    I am with the above posts...
    Follow the service manual.
    What will fail?...unknown.
    At 63K and 11 years...
    Preventative maintenance:
    Lube brake pad pins...known issue
    12V battery replace...3 to 5 year trouble free life
    Trans oil change..many say 60K good time to change
    Make sure brake fluid has been changed...age
    Test coolants and replace if needed or just replace...age
    Check suspension bushings (actually all rubber mounts)...age
    Lube door, hood, trunk hinges
    Because of electrolysis, remove and inspect sparkplugs, replace the plugs using some anti seize.
    That's my two cents.
  6. wirelessjava
    wirelessjava Member
    103
    Union City, CA
    Hey this is a nice list s Lube Brake Pad Pins..... I did not know this is a known issue I need to look this up
    I think my suspension needs to be changed shocks or struts.
  7. bisco
    49,726
    that's more about rear disc brakes on gen 3, cause they don't get used much. front discs on gen 2 aren't an issue.
