What Would YOU Do: Dented Bumper
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jk823, Apr 30, 2015.
  1. jk823
    jk823 Member
    100
    Los Angeles CA
    so I was rear-ended in a hit and run this week, which dented my rear bumper and made the panel start popping off the side of the car. Ive been to two auto shops and got two very different opinions for how to proceed. (Photo below!)
    - one shop said that for $425 I can have this bumper repaired and repainted
    - another shop said I'd be better off replacing the bumper (and small plastic spoiler underneath) with after-market replacements for $600.
    If it was your car, what would you do? Besides price, are there pros and cons?
    52,849
    i'd go with the low cost repair, but i don't know the cons.
  3. jk823
    jk823 Member
    100
    Los Angeles CA
    That's kind of what I was thinking. Just wasn't sure if there was anything I needed to consider before doing that.
    52,849
    i guess the only consideration is how difficult to repair the plastic bumper. maybe someone else knows, but if the shoppe is reputable and will guarantee the work?
  5. bisco
    52,849
    $600. isn't a bad price for a new bumper cover, painted and installed either. but again, i'm not sure of aftermarket quality.
  6. Okinawa
    Okinawa Senior Member
    1,333
    320
    If the $425.00 is a reputible shop I would go with it.
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'd try heating up that bumper and seeing if it pops out.
    Hey, it works on youtube.
    Otherwise? I'd look up reviews for both body shops and pick the one that is highest rated with the most positive reviews.
    Either approach is NOT good if not done well.
    You also could visit a few other shops just for a free estimate and to get a larger consensus of opinion.
    Dino33ca and Okinawa like this.
  8. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    DIY: Toyota Prius Bumper Dent Fix with a Hair Dryer - Video
  9. The Electric Me
    9,083
    5,801
    That's what I was thinking.
    I've heard it actually works. Never really witnessed it in person.
    Some people use a heat gun...little stronger than a hair dryer.
    I just want someone to try it and report back.
    Selfish curiosity.
    Sergiospl likes this.
  10. JC91006
    16,936
    8,647
    If there are no flaws on your car, other than the bumper now, I would not repair it myself. Spend the $425 and get it repaired properly. The OEM will always be better than the aftermarket bumper.
    If you DIY the repair, you'll have a car that's going to show the damage.......and when it's time to sell it, the buyer will knock it's value by at least $425. So why not just pay for it now?
    Okinawa likes this.
  11. WFBowen
    WFBowen Junior Member
    16
    Southern Calif
    I've owned 2 body shops and have restored mostly classic/collectible cars for the last 40 years. Your best solution is this: Experiment with the hair dryer/heat gun method or just leave the cover as-is. Since you live in L.A. (the center of the universe for Prius sales and wrecking yards) actively look for an excellent used bumper cover with original (Spectra Blue?) factory paint. Then just swap the covers yourself. You might even find something on Ebay, but seeing it first-hand is preferable.
    While I watched the various heatgun solutions, it's my experience that the bumper material (or sheet metal in other examples) will always stretch when heavily impacted - which will leave you with a something less than perfect result. Also, the major cost in repairing a bumper cover is the final paint which is not that easy to duplicate (you can use a blending lacquer on the adjacent panels, but this will oxidize at a different rate down the road.) Whatever you do, i.e. repair the cover or purchase a new replacement and have it finished at a shop, you will not do better than an OEM part with its original factory finish.
    JMO, Bill.
    #11 WFBowen, Apr 30, 2015
    Dino33ca likes this.
  12. The Electric Me
    9,083
    5,801
    Can't argue with that logic. BUT...that's no fun. How often are we afforded the luxury and excitement of heading towards our vehicles with a glowing heat gun?
    I just want to see if it works at all! If he's going to have it repaired or replaced...it's nearly a blank check in the attempt. Assuming he doesn't do a lot MORE damage trying to get it to pop out.
    I'd be a little careful...but I'd be sure tempted to try.
  13. Mendel Leisk
    42,343
    The site could use a "muzzle" emoticon, I'm so teed off with the current state of useless bumpers, gotta restrain myself.
    Anyway, I'd go the cheaper refurb repair route. If for no other reason than to avoid dumping more piece-of-cr@p hydrocarbons in a land fill.
  14. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    Heat and a bit of pressure from behind will pop it out - I did this on a 1998 Grand Marquis back in the day. The bumper was dented severely in the front. Heat, pressure, a bit of rubbing compound and wax to finish the job and I saved quite a bit! The car looked fine when all was said and done. It does not hurt to try a DIY dent removal. The worst that could happen is that you will replace the bumper, right?
  15. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    I can't believe it would take much more effort to drop the entire bumper cover and inspect further damage. But maybe you can already assess this from underneath the car. Granted I wouldn't expect much more damage but while you had the bumper cover off you should easily be able to push the dent out after its sat in the sun for a little while.
  16. Priusyipee
    354
    269
    Upstate New York
    True but depends on the OP and how comfortable he is with removing the bumper cover.
    Personally, I would never go for an aftermarket part. Difficult to fit as the holes do not always line up and the materials are inferior to OEM.
    #16 Priusyipee, Apr 30, 2015
  17. Freedom
    Freedom Active Member
    553
    73
    Northeastern MA
    I was rear ended 3 times in 8 months. Fortunately, I know of one local auto body shop with also does the work for the local Toyota dealer. (Mine were not hit and runs, the other person's insurance paid for everything, including my deductible).
    So I would suggest finding a shop who works with a Toyota dealer; and get a price from them! Then decide who to go to.
    If you are handy, I really like the suggestion to find one at a salvage shop and replace it completely, on your own.
  18. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    the heat gun/ hair dryer trick does work. I've done it. but a heat gun can melt the paint and even the bumper itself if your not careful. I would try a hair dryer first because it should soften the plastic without getting hot enough to damage anything. the rear bumper does come off fairly easy if your handy, it's best to have a friend to help, and spread something soft under it so you don't drop it on the street and scratch it. you might be able to just unhook the one side and move out just enough to get a hand inside it to press on it while you heat it up with the hairdryer.
  19. Patrick Wong
    18,210
    6,517
    If you decide that the bumper needs to be replaced, it would be better to install a used original equipment part (if such a part can be sourced) instead of a new aftermarket part with a dubious fit.
    If the bumper cover can be repaired, that would be a reasonable choice. It is hard to say much without seeing some photos of the damaged area.
  20. bisco
    52,849
    there is a photo in the first post.
