What would you do? Totaled but (maybe) fixable Gen 2
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Pheasanton, Apr 23, 2026.
  1. Pheasanton
    Pheasanton Junior Member
    PA
    An upstanding citizen hit my parked Gen 2 and did not leave a note. The back window glass, spoiler and liftgate release, and various bits of plastic around them are destroyed (lights still work).
    In retrospect, I shouldn't have gone through insurance and should have just gotten the critical stuff fixed myself - lesson learned.
    But I did go through insurance and they have declared it a total loss based on the shop's estimate of about $4k to fix it. If I take a buyout and keep the car, I'll get a check for $4200. Deductible is $500, so $3700 in my pocket before paying for repairs.
    It seems like it would be easiest to buy an entire scrapyard liftgate and have a shop install it for me. (Zero skills here - I can't do it.) But I'm in Pennsylvania and I understand that a salvage vehicle can't be driven and has to be towed to the shop and again to the "enhanced inspection" which requires, among other things, that the reconstructed car have a uniform color. So it'll be harder to find the right hatch, $$ for towing, and a general PITA.
    The car is in pretty good shape for 160k miles and recently passed inspection. It took months to find a good condition Gen 2 and I'm dreading the thought of having to do that again.
    What would you do?
  2. JC91006
    16,936
    8,647
    If the hatch is the only thing that needs replacement, that should be an easy find on the used market. In CA, I have friends that can't sell this part, since there is not much demand for it, can be had for $200 or less. The front end parts are the harder parts to find.
    Since it took you a long time to find a good gen 2, and yours only has 160k miles. I would fix it.
  3. Tombukt2
    Tombukt2 Senior Member
    13,845
    2,515
    Durham NC
    I have everything right here on the property to fix that car in one afternoon generally 8.make sure of it. I'm getting a lil low on some stuff now . Another coming any minute . Anyone know anybody that wants an Aprilia S500 for near free in like new condition?
    PriusCamper likes this.
  4. PriusCamper
    PriusCamper Senior Member
    13,440
    5,426
    Pacific Northwest, USA
    If I were you, I'd plan a trip down to Durham and have @Tombukt2 do it for you... Or just have a friend or family member with more skills assist you. Swapping out the rear hatch door is as easy as unscrewing 4 bolts and unplugging a wiring harness. It's a very easy job.
  5. Tombukt2
    13,845
    2,515
    Durham NC
    Yeah I changed my whole hatch to avoid putting a glass in. zPA is a haul
  6. Pheasanton
    PA
    Thanks for this. The shop has come back to add that the rear antenna (part no. 8999747010) and a piece of the rear trim (6471647010B0) also need replacing. I wouldn't worry about the trim except that PA won't pass a rebuilt car unless it's back to factory standard. Would that change your math at all or would you still say go for it?
    (wish I could get to NC but it's a bit of a hike!)
  7. bisco
    52,817
    so it was going to cost you $300 net, and now what?
    is the car great otherwise? 160k is low mileage, and if it doesn't burn oil and there's no rust, I'd be willing to put in a few grande.
    plan on battery replacement in the near future if it hasn't been done
  8. Pheasanton
    PA
    Appreciate that, thank you.
  9. BiomedO1
    BiomedO1 Senior Member
    4,562
    2,394
    Left Coast
    For a 4K estimated fix; I'm pretty sure it's a little bit more "bent" than just a rear hatch - unless all body shops out there are crooks. Seems to me that the body shop would've gave you a used replacement option and waived your deductible. That's what they do around here with a cheap car that someone wants to keep and fix. They even match the paint; so you avoid the salvage title brand on your pink slip. But all that's out the window, since the insurance company paid out and branded the car title.
    Just my two cents.....
  10. Tombukt2
    13,845
    2,515
    Durham NC
    None of that trim will be worth worrying about you're going to get it off of used car hopefully I don't care what PA says been they stuff in Pa before . Of course the car is going to be in replaced shape . It's just lightweight damage . This is something you attempt in the driveway . It's really easy . Even by yourself
  11. 6079smithw
    6079smithw Junior Member
    22
    N. Nevada
    I'm thinking that estimate's a little tall myself... Was the shop in question one you picked or was it recommended by the insurance company?
    If it was theirs, you may want to take a good set of pictures and do a little shopping around. Im with Mr. Tombukt2 on this one; your car
    sounds like it's worth the legwork. Can you post a photo or two of the damage? Just me, I hate to see insurance companies get anything
    other than a bad reputation...
  12. PriusCamper
    13,440
    5,426
    This is the correct answer... The cost of running a legit body shop is profoundly expensive and primarily focuses on cars that are less than 5 years old. So bringing in a Prius that's 20 years old means they know the value of the car is likely going to be lower than the cost of repairs if they replace with brand new parts and matching paint. There's nothing smart about putting super expensive brand new parts on a 20 year old car!
  13. Prius_Gnome
    Prius_Gnome Member
    110
    39
    Long Island, NY
    Before spending the money to fix it up, I'd suggest you get an estimate on how much more expensive car insurance would be on a salvage-titled car than a clean-titled car. I have no personal experience but Google AI says it might be 20%-40% more expensive (which then increases your total cost of ownership which means you might be better off with another car that's clean-titled). If you're comfortable paying more on future auto insurance premiums on your current salvage car, then go ahead and look into fixing it up.
    Otherwise, use the $3700 to help purchase another car. And if you're purchasing another Gen2 Prius, you can use the current salvage car as a donor car for parts to help fix/replace anything on the newly purchased Gen2 Prius. Or maybe just sell the salvage car for parts or minor cash at a salvage yard, if you don't want the hassle.
  14. Tombukt2
    13,845
    2,515
    Durham NC
    Let's see some pictures that'll put this to rest really quick if just cosmetic . Then should be no brainer
    frodoz737 likes this.
