What wuld happen if I....
Discussion in 'Gen 3 Prius Main Forum' started by adamace1, Jul 7, 2009.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Correct. If the Prius is in Ready the ICE will operate until you run out of gas.
    Tom
  2. jim256
    jim256 Member
    317
    69
    Eastern NC
    I guess I'm reading "hybrid system not operating" as critical-since it could be in ON without being in Ready if you never depressed the brake pedal to initialize the hybrid system.
    I know I won't test this intentionally, probably won't occur at all since this is my third car with SKS and it just doesn't happen. Great convenience, no hassles, warns me if I leave with the key when it's running.
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I remember the terminology used with the Gen2, and I suspect the Gen3 is the same, "ON" actually means Accessory Mode entered by pushing the ON button without depressing the brake. "Ready" means you pushed the ON button with the brake depressed and the car is ready to drive - or sit there and run for days.
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    uhh.. sitting on with the radio on.. without A/C.. it's about 1 gallon every 12 hours.. With A/C it's 1 gallon every 6 to 12 hours... so.. with 10 gallons ( haha.. 10 never happens ).. you have 3 to 5 days to find the car in Ready mode.. and turn it off.
  5. jim256
    jim256 Member
    317
    69
    Eastern NC
    It's ACC (switch is amber without pressing the brake pedal), a second press gets you ON (still amber without depressing the brake). Ready comes when you press the switch with the pedal having been depressed. The switch light is green once you depress the brake. ON alone lets you run the power windows without having to start the car, ACC will allow the radio but not windows.
  6. tumbleweed
    4,067
    692
    Eastern Oregon
    OK thanks Jim, I finally found it on page 164 of my pdf owner's manual.
  7. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    this is just weird.
    i just read everyones posts.
    It just seems that toyota would put in a auto off for the ready mode
    say if two things happened
    1. car has been in park for more than 3 hours
    2. no doors are opened or closed for the 3 hours
